Need the water return pipe that takes the water back to the header tank.
Must be a short 4x4 one with the 90 degree bend in it not the 2wd one that runs across the top of the rocker cover.
Cheers Rich
mate the 4wd pipe is long as it runs accross the front of the front panel,I presume your using it on a 2wd as you jave the 4wd header tank ???
just cut it to size
