- enyone own f200 dls?
- please help!!!
- what colour wheels shall i go for????
- air charge temp sensors
- Knocking from front
- What wheels
- Series 1 fuel pipe dilemma
- Charging problem s2 urgent
- Side lights / Dip beam !!!!!!!! SORTED
- Sparkplugs
- Front spot lights
- my big end bearings, what are they, which ones to get??????
- cvh pumps (1.8 same as 1.6??)
- Dave Y
- part number ?
- ecu chipping
- best time to visit the uk
- clutches
- anyone got a magnex flexi?? urgent..pleeeese
- I started building this car on july 14th 2005
- getting my rs turbo chipped ?
- Air/Fuel gauge
- RST steering wheel in a mk4?
- Mk5 clutch pedal on mk4 !!!!!
- rocker cover gasket.
- Info please on bottom end bearings
- Anyone run a S1 gearbox in a S2???
- 1AFA WIRING TO FIT OFAB
- Starter Motor Wires
- What is the standard boost pressure for a s2 ??
- who runs black and silver number plates?
- Engine bay clean
- My S2 some subtle bits
- WTF
- White Lightning meets English Electric Lightning
- Limit on a standard S1/S2 exh manifold ?
- Still Cool !
- vernier pulley
- how do u baffle a sump on a cvh???????????
- gauges
- Koni's - short or std
- Series one gearbox into a S2?
- S1 intercooler conundrum.....
- chassis number when replacing floorpans?
- CP2000-35 Clutch
- Another electrical problem
- big end bearings
- think i have finally decided to sell...
- Who running a ZVH without altering the compression
- Are Fiesta RST Cams the same as Escort RST's?
- Anyone else had this from a Mongoose exhaust ?
- new to the board and my new rs
- My S1 pictures..... at last.
- low rst
- Bigger brake conversion???
- Finally sorted out my rear lights
- dog has just ate my towing eye cover anyone have one
- FAO: All zvh and zetec turbo owners
- rear gearbox mounts
- help s1 cutting out
- HELP!!!!!!FUEL METERING UNIT**FIXED BY---JAMSPORT*****
- ABS removal
- Fiesta fitment Gearbopx into Mk3 Escort.......
- Series 1 boot lock.
- Help! - Car not starting
- DISCO LIGHTS ON S2
- my rs turbo
- .49 a/r exhaust side on a t25????
- s1 ecu chipped or not?
- s1 or what
- best oil
- 2 ltr zetec bottom end help need urjent!!!!!!!!!!!!!!!
- GRS coolers
- running problems and some fault codes
- vin plates
- S2 starting and missing probs! (fixed)
- anyone have 17"rondells and big brakes?
- brake pipe question
- port and polished heads, do they really work???
- brakeprob when fitted rearbrakes....
- t3/4 turbo
- fitting ZVH engine
- quick shifter piccys
- fwd hydrolic clutch
- What else to change in the g'box area ?
- TUNING
- increase boost
- bleed valve
- spoiler bolt pattern
- slow turn over when hot
- lowering compression on s2
- shit new MOTs, need help
- size 4 headbolts for ZVH conversion
- CVH Camshaft quality
- charge cooler v intercooler
- Just fitted the zvh. few questions.....
- gaz or avo coilovers
- Rear Coilover Conversion
- s2 rst van
- removing boot lid off s2?
- S2 bottom end
- are the crankshafts of a xr3i an rs turbo the same?
- S1 people with gauges
- vacuum gauge
- Tool for stem seals
- taking metering unit apart???
- picture request for s1 bits
- safety device cage
- boosting an 1989 uk import xr3i efi
- Adjusting boost on a -31 actuator
- water wetter
- Who's running 0.48 exhaust housing
- Piston ring gap question
- rs 1600i rocker cover
- Cosworth Racing Piston HELP
- piston ring measurement, please help
- mind that gap
- electric windows fuse keeps blowing
- Low Comp vs's High Comp
- Gold members....
- converting carb head to efi
- DOES ANYBODY KNOW THE LINK FOR THIS SITE???
- Series 1 BOOT switch (just for you Rick)
- Engine getting too hot??
- set up needed fitting intercooler?
- Brake brakets
- S2 servo and master cylinder
- knock from front
- 17 x 8" alloys on s1
- water coming in
- to the judges this goes ...views please
- Rear opening screw covers
- saab exhaust housing ????
- series 1 owners
- boost cut
- Top adjustable strut mounts for a S2?
- Help please!!
- Grp A coil.
- Indicators
- differences between 1.4 efi head and 1.6 efi head
- S1 RST Wiring diagram
- Efi
- S2 front mount on an S1
- big valves ?
- Very cheap series one F/M cooler and carrier for sale(again)
- alternator
- temp
- headlights
- cosworth front brakes
- Car won't tickover
- Cutting out and backfiring!!!
- rs tunning whos good
- cold start injector
- Thanks everyone!!!!!
- would this clutch be any good for my RS turbo?
- any tips please
- fuel pump wiring
- were would u go 4 rr tune
- amal disconnected
- s1/s2 ecu question
- Speedo problems
- oil temp 110 2 120 degrees c when driving easy
- How to install ARP Head Stud Kit
- scorpion ex mounting help
- Any advice on what to do with my roof?
- EFi Rev counter on mk 3 escort.
- Steering question after changing steering wheel...
- T3 turbo
- Cosworth Calipers
- cts gearboxes
- cooling
- struggling to start from cold,ideas please (s2)
- Boost
- Efi Conversaion starting problem.
- hot oil
- FAO Series 1 Owners, Pic request please!
- Can anyone help with this headlights problem??
- timing advice needed for piper 285 t2 plz
- wastegate crack
- running hot
- warm car/ low fuel pressure..S1
- Try and diagnose this if you can!
- are these any good?
- Basic setup for an S1 RST?
- severn valley cam ?
- Efi head adapter plate???
- Lightened and balanced flywheel? how can you tell?
- Amal Valve Wiring Problem
- fao turboboss
- help!! turbo not spinnin an d/v not dumpin anythin
- Part number of headgasket
- In a 'stuff it' mood ...
- RS turbo Radiator - where to buy??? help please!!!!
- 2nd car
- RADTEC INTERCOOLER
- RS TURBO TUNERS
- escort cossie alloys
- overheating S1
- S1 rs turbo poly bushes
- brake pads whats better
- washed and took out the s1 today
- 1.9 american tall block
- Scorpion down pipe
- zvh conversion on frst..... oil leaks problems the whole lot
- rs turbo on gt30 and tubular
- series 2 electrical help please
- Replacing Clutch
- Massive back fire very strange....
- can u still get koni coilovers
- agggggggghhhhhhhhh bloody car
- relays
- REAR DISC COVERSION (AGAIN)
- torque settings
- found these in the usa ????
- New mk4 Shells!!!
- fuel pump priming
- T34 v T28
- RS Turbo Chip
- injector size
- Cone filter Standard filter that is the question????
- new pics of my car
- Anyone from around Bedfordshire?
- S1 wont start
- alloy help
- leather escort?
- TOURING CAR SPEC S2 GEARBOX.....................LOL
- TURBO PROBLEMS NEED ADVISE
- Another EFI conversion thread..........
- B&M Quickshift fitted
- Rs Turbo amal valve Vs Bleed valve discussion
- Prices when breaking
- QUICK!! Pricing help needed
- Efi covertion using xr2i loom
- clean samcos
- co screw /stalk meaning cant fit induction
- changing lifters
- momo steering boss problem maybe??
- EFi relays
- Bore liners on an RST block?
- My Series 2... Finally
- dummy alert!!!
- How much ?? Advice plz
- Efi Conversion Crossover Pipe
- wot spins up quicker?
- would anyone be interested in cosworth pistons for the cvh?
- wot colour for s1 reshell
- series 1 reshell advise
- s2 rs???
- opening 1/4's
- What should Boost Gauge Read
