can u still get koni coilovers
Can u still get koni coilovers ive tryed a few places and koni them selfs and they are not listed , or wot other make can i get ???
ive got spax 30 mm drop but their to soft , would adjustables do ? are adjustables coilovers dont quite understand this suspension stuff , can you set ride height n hardness with adjustables ??????
Koni adjustables are damping rate adjustable only.
Coil overs are height or height and damping rate. You can also swap and change the spring compression rate as well. Others need the insert changing to adjust the damping rate.
So the answer was no then..
Why would the spring need to come from Spax ?
Those are the Bilstein ones btw
https://passionford.com/forum/viewtopic.php?t=107112
Passionate about fords
thanks rick, just realised its the mef ones lol............what i meant was i didnt think bilstein actually made them themselves. these are bilstein inserts arent they ????.
any idea what colour the old konis were?
ive got a set of konis on mine, their all yellow, not sure whether their adjustables or coilovers but i know i can go a full car with 3 ppl in the back 13stone each and it dont even move let alone rub.
truffleshuffle
10-09-2015 09:35 PM
