EFi relays
Old 14-07-2006, 06:55 PM
tim10_10
tim10_10's Avatar
Default EFi relays
Im starting my efi conversion tomorrow just need to make sure that the fuel and ecu relays are the same and are they yellow ones about an inch square?
Old 14-07-2006, 07:34 PM
ian r
ian r's Avatar
fuel pump 1 is yellow
Old 14-07-2006, 10:31 PM
TURBO BOI
TURBO BOI's Avatar
this is what you want
dont use the ones that are in the s2 original fuse box as the circuits are different as i found out 2day
Old 14-07-2006, 10:46 PM
tim10_10
tim10_10's Avatar
Ok thanks looks like the ones I have.
Old 14-07-2006, 11:22 PM
NEWTON
NEWTON's Avatar
the ecu relay is red
Old 15-07-2006, 05:35 PM
tim10_10
tim10_10's Avatar
If the ecu relay is red is it the same size as the yellow one pictured above or is it the taller one?
Old 15-07-2006, 05:42 PM
TURBO BOI
TURBO BOI's Avatar
yep same size
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
phil51
Ford Focus Diesel
02-10-2015 01:00 PM
IainRS1700T
25-09-2015 06:44 AM
RSmark84
13-09-2015 01:29 PM
dms04
11-09-2015 01:57 PM
Quick Reply: EFi relays
