S2 starting and missing probs! (fixed)
Old 28-07-2006, 06:30 PM
rsj
rsj's Avatar
Default S2 starting and missing probs! (fixed)
im posting this 4a freind,
Here we go... right he brought an s2 on thursday he said when he got it it was running fine but over the last 2 days its started 2 missfire and have trouble 2 start....ive had a quick listen bth im no wiser than him, sounds like its running on 3 cylinders wont rev past 3500rpm on the road its gutless hes tryed new plugs leads coil rota arm cap still the same...but when u pull the oil cap off the engine stalls instantly? does this mean its low on compression??
any ideas ppl??
Old 28-07-2006, 06:35 PM
RST Ski
RST Ski's Avatar
pulling the cap off and it stalling is normal because the breather system needs to be sealed for it to run, by pulling off the cap ur causing a air leak so thats normal
misfire could be caused by a number of things, do you no which cylinder is not working? a compresion test is worth doing for this fault tho, as you say its got lack of power too
any work been carried out on the car recently? worth checking the fuels lines from the metering unit to the injectors for leaks ect
Old 28-07-2006, 07:15 PM
gup
gup's Avatar
could be the injecter try pulling the ht lead off one at a time (with the engine off) starting her up to c if the engine note changes
had this on my bros series 1 been in it for ages parked up for about half an hour and it started to miss
no 2 injecter failed luckily it was outside our home
Old 29-07-2006, 08:20 AM
HORNETS7
HORNETS7's Avatar
might be a dodgy spark plug or ht lead or even dizzy cap !
change em can only make it better!
Old 19-08-2006, 12:41 PM
rsj
rsj's Avatar
sorted..after changing almost everything and no joy he took the car down 2 nms ollie had a god few hours onit in the end it was the camshaft worn the lobes off new cam in and away she goes ......but now developed a nasty bottem end knocking!!
JoeyBoyden
04-01-2024 02:36 PM
martysmartie
06-09-2015 10:22 AM
Bailes1992
03-09-2015 02:17 PM
fish6634
Ford KA
02-08-2015 01:02 PM
CabrioTurbo
01-08-2015 11:04 AM
Quick Reply: S2 starting and missing probs! (fixed)
