Who's running 0.48 exhaust housing
I am just about to fit my new 0.48 exhaust housing as my other 0.48 housing had cracked around the wategate. How laggy is it over standard when they're not carcked? I'll be running about 18psi on standard cam.
no where near the snappyness of the .36 but a better housing for reliability and heat issues.
got one fitted to mine with similar spec to yours and fairly happy although may change to a .36 in the future...lol
I'll swap it over in the morning then and see how it goes. Seems to be a common fault with the housing cracking. I've got 3 housings sat at home and all have cracks around the wastegate. At least I got some to practice welding on.
got mine today, just wondereing if there are any issues with the bonnet catch as I still one run one, all the grs ones I've seen have a dent in the top?
thanks
thanks
na dont need to rev it at all, its just a more harder hit in my opinion
the bigger boys on here are probably better to ask
i just like the look on my mates faces when it bangs in and their head goes back in the seat!!
i bought my turbo off a member on here, fair play its been sound as a pound so far.
its a T34, 360 bearing with .48 housing off a saff cosworth
yes, the hit is hard
and from what the tuner told me hes only set it at 9/10 psi
nice bang but not too much torque steer
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Just changed my .36 housing for a ,48 and have to say I've noticed no difference at all.
Probably because my car is at the workshop and I've not even seen it for a week
Workshop? Don't you do the work yourself then?
The only time I take my car anywhere is to get the fuelling setup.
One of my boost hoses blew off on the way to work this morning after changing the housing over to the 0.48 one. Found it was down to a faulty jubliee clip. Crapped myself when I heard a rush of air and the engine dying thought I'd blown the turbo.
put a .48 on mine, an the car totally changed, whereas i used to race a couple of bikes home from work down the back roads, and give them a good thrashing (cbr 400 and dtv250 2 stroke) but once that .48 went on it became an A road car so started taking thje a12 home and goin off the clock instead and the bikes done me on pull away out of the bends..
i think if im right it allowa exhaust gases to flow better thus reducin the chance of turbo stall on higher boost at higher revs...
so in affect will be bit laggier but rev better...
i have a 48 on mine and i love it!
The only time I take my car anywhere is to get the fuelling setup.![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
