my big end bearings, what are they, which ones to get??????
on my big end bearing i have v85sf 6211 AA B5 on one side and
220172 with a ford stamp. Anyone know which big ends i need. I want heavy duty ones and where from please too. thanks guys
go to an engine reconditioning place they will be able to get u the correct bearings!
have u or do u need the crank grindingf or polishing cos the shells will need to match the machining work done on the crank!
wasnt going to take the crank out. someone said a bit of wet and dry to get it nice and smooth, it feels pretty good, should be ok and then get a set of identical bearings. I really cant be arsed to drop the gearbox again to get it all out
Best thing to do, if you have one, use a digital vernier and measure the jurnel (sp) to see if its still in tollerance. this will also let you know what size bearings you got, standard size, etc.
if you are within tollerance, then like you said, wet and dry them smooth, thats what i did, look spot on now. and you cant take to much off with wet and dry as its all harderned.
As for heavy duty bearings, Burtons your place for them
Just showed the bearings to a mechanic and he told me i should get a new crank and ideally rebuild the bottom end. he has put new shells in after sanding and said it lasted 5 mins before it went again. so looks like im going to try and find a new(used) bottom end from ford fair as i cant wait 3 weeks for my mondeo to come off the road and use that for a zvh conversion.
Might be worth getting the crank ground down and put in undersize bearings. Will cost about Ł100 then you've got a good setup and won't have to touch it again.
will wait till tomorrow morning till ive crained the engine out and will check the bores/pistons etc and see what the state of play is.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
