PDA
View Full Version : Ford Sierra/Sapphire/RS500 Cosworth
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71
  1. 4WD lambda sensor wiring
  2. Problem after fitting rs 500 intercooler
  3. History on Ford Sierra Sapphire Cosworth 1988
  4. 4x4 cossie osf wheel bearing
  5. Engine guru's PLEASE HELP...........
  6. 3dr Price Guides
  7. Sierra Cosworth Wolf
  8. Photos of hubs?
  9. refuelling issues ...
  10. cosworth plug leads 10 mm
  11. what is roll center?
  12. Black 4x4s
  13. Radio - code locked out on 89 Saff
  14. three door electric window winder question
  15. disassemble a three door wing mirror - how to ?
  16. Electric Window Problem
  17. Sapphire Cosworth 4x4 tyre size
  18. sierra overheating problem
  19. spark plug help!!!
  20. What aftermarket tacho to use in org. place ?
  21. Ooppps ??
  22. car just cut out, HELP!
  23. rear diff hanger
  24. ahmed bayjoo 3dr springs
  25. Koni Adjustables Question on 4x4 Cossie
  26. compression strut vs ARB
  27. Strang boost
  28. 3 door cosworth
  29. cossy problem
  30. Rear Underside Refurb?
  31. lower sapph
  32. T5 Gearbox
  33. p8 ecu
  34. best ecu?
  35. Ford Sapphire cosworth in Moonstone blue.
  36. Garrett Turbo .t3 Compressor Wheel+housing Upgrade Set
  37. 3 door gearbox
  38. 10/20mm inlet spacer
  39. refurbed rocker covers
  40. New mountings for the anti roll bar, cosworth 2wd
  41. pulley cambelt tensionner fitting position
  42. 3dr speedo not working
  43. Handbrake cable ??
  44. Loss Of Power At 5500 Ish
  45. Dizzy blanking
  46. fuel pump 3dr
  47. knock sensor
  48. Cracked Block....
  49. T5 box
  50. Cossies Exhausts Sounds
  51. clutch choices
  52. 3 Door Low Voltage - New Alternator Needed?
  53. Solid lifters when, where and how
  54. 2wd sapphire running and starting problem
  55. new VIN plate
  56. cosworth 2wd hubs
  57. Brake Servo
  58. 4x4 shafts
  59. 3 door first aid kit ...
  60. Rouse seats
  61. Koni shocks repairing.
  62. Mecanic lifter
  63. brakes probs anyone help
  64. Remove transfer shaft from 2wd cossie
  65. Headlight, fog light + surounds?
  66. Another Brakes Q
  67. idle control valve
  68. Head Bolts...
  69. Problem with brakes
  70. exhaust problem
  71. Saff cossie head lining.
  72. bosch plugs
  73. Merkur/Sapphire windshield
  74. Handbrake light stuck on after a job
  75. kent cams
  76. Rear Bumper
  77. Saff Boot Not Locking, Any Help???
  78. MT75 Input Shafts
  79. Near Side Hub For 4x4 Cossie Needed Asap
  80. fuel pressure regulator.....
  81. tensioner pulley cambelt torque
  82. saph chassis rails
  83. Turbo to Down Pipe Gasket???
  84. rear arms Pics from 3dr cossie,wanted
  85. turbo housing
  86. 4x4 Cossie Eating Cv Joints and Boots
  87. Wanted T34
  88. Gasket between exhaust manifold and turbo ? and boost problem.
  89. TUNERS
  90. std air box or cone filter
  91. best oil
  92. brakes upgrade - pic request
  93. boost presure
  94. saff cossie head lining
  95. 4x4 rear number plate panel - Early 2WD Saff?
  96. Water pump to bottom radiator hose
  97. Sierra RS Cosworth D reg 2WD Rough Running
  98. wanted
  99. 3dr vin numbers
  100. 4x4 and 2wd HT lead difference?
  101. ford sapph grille badge
  102. If the sensors equally between Germans and English Cosworth engines?
  103. escos rims & ap's
  104. What wide arch bodykits are there
  105. 4x4 head onto 2wd saff ?
  106. Smoking Cossie (Nothing New I Know)
  107. How can i find out what colour my saph left the factory??
  108. standard turbo?
  109. Which Car Alarm - West Midlands
  110. swing arm bushes..??
  111. 205 block limit?
  112. Amal valve clicking?
  113. Changing The Valve Stem Seals
  114. No boost over 10psi
  115. brake problem
  116. Service kits for 4x4 calipers
  117. Oil pump removal
  118. 4x4 saph brakes
  119. hazards not working
  120. Brake lights just stopped working
  121. lamber sensor
  122. After Market Fan Loom
  123. Mk1 Vs. Mk2 Steering rack Interchange?
  124. hand brake problem........what have i done?
  125. cracked block....
  126. MAP Sensor Vacuum Pipe Length
  127. Cosworth Original Dampers
  128. Pics of underneath 4x4's
  129. Saph bumper fitings?
  130. Petrol Tank Question
  131. Fitting Door Mouldings... Sorted!
  132. bd10 and timing value (reality/ theorical)
  133. Big thanks to tabetha and kSA-cossie
  134. Amal valve location / fixing
  135. Will Escos Hubs/Carriers fit Saff 4x4??
  136. Bad misfiring issues
  137. Indicators not cancelling
  138. HELP
  139. has my turbo gone
  140. sapph front windscreen seal
  141. What ECU will this chip I bought fit? L6 or L8??
  142. Front fog light wiring - 4x4 or 2wd - the same??
  143. Chips and ECUs
  144. Head gasket oil leak
  145. focus rs alloys on a saph
  146. Another Stupid Question
  147. Noisey T5 Box On Idle
  148. torque settings??
  149. Turbo Cooler Fitted To My Saph 4x4
  150. Plug
  151. 3dr cosworth buying guide
  152. Alternator and PAS Belt Size?
  153. New engine loom...
  154. interior trim pic's please..
  155. Were have you monted your gauges?
  156. changing front discs!
  157. Comp strut and TCA failure pics
  158. rs500 style splitter
  159. Removing white dials?
  160. refurbishing 3 door wheels
  161. 2wd cossie pin out?
  162. Ignition lights not working
  163. Amp Blank Tray Ref no Required please
  164. 071 spark plugs
  165. Cosworth 2wd distributor seal
  166. 4x4 idle control valve
  167. Where to buy NEW hub carrier?
  168. saff cos now idling funny,like it hunting, when it comes on boost its misfiring??
  169. How hard to remove 4x4 saph front diff????
  170. Arp Head Bolts
  171. Cosworth losing power
  172. Heater not working
  173. Revotec Gauges
  174. what offset for sapphire cosworth wheels
  175. saph parts..
  176. brake help
  177. What spark plugs?????
  178. Clutch Cable Routing
  179. oil pump...:(
  180. Fuel tray - pump rubber mounts
  181. cosworth pressurising
  182. Rad Fans
  183. 18's on 3 door
  184. dodgy rev counter
  185. are saff cossie 2wd calipers the same as 4x4 ones?
  186. 4wd intercooler????
  187. do esc cos heatsheilds fit a saph??
  188. cams ?
  189. saphire tyre info!
  190. clutch for 550 brake?
  191. Bonnet Underlay - Yes or No
  192. Changed my clutch - won't grip :S
  193. 7.5" diff into a 4x4
  194. close ratio ?
  195. Rear Beam Bushes
  196. BHP limit 4wd exhaust manifold
  197. stalite valves
  198. you need deep pockets.....:(
  199. t5, changing input shaft bearings
  200. are these the right plugs for my saff 4x4??
  201. Where is temperature transmitter
  202. 4x4 Saph front diff
  203. Saff splitter removal?
  204. speaker sizes..???
  205. Opinions on my non-working 2WD brake master cylinder
  206. Gt28 turbo
  207. Removing/refitting Saff front bumper?
  208. Mk1 Sierra Ghia 2.3 V6
  209. 205 block piston trouble
  210. Clutch needed
  211. 8j by 18 inch et30 ?
  212. Bonnet bra thingies??
  213. A few questions about parts I need..?
  214. Sweedish plenum.
  215. stage 3 boost ?
  216. Speedo not working
  217. Fuel line removal
  218. Wiring problems now!
  219. wide ratio/ close ratio gearing
  220. Removing TCA & balljoint
  221. closed loop
  222. central locking problem????
  223. my way of sorting the side skirts clip problem
  224. wot gearbox oil and diff oil for a 2wd cossie?
  225. 3 Door Ariel on n/s ??? Answers
  226. rs500 or swedish plenum?
  227. TÜV approval for springs?
  228. throotle cable lengh
  229. Coilover question?
  230. wot engine oil for a 2wd cossie?
  231. 2wd vs 4wd thermostat housings
  232. 2wd heat shield
  233. Racing Plugs
  234. 2wd head needed asap
  235. help mounting mongoose exhaust
  236. high revs
  237. overheating
  238. 3 door on escort cos wheels
  239. ngk bcr8es gap
  240. Couple of 3dr project questions
  241. Rewiring fuel pump
  242. 909 outter tca bushes
  243. AP Brakes - anti squeal clips?
  244. How hot do your Cossie's run?
  245. rim problem
  246. 3-dr Melted Fuse Box
  247. frothy power steering fluid
  248. opps...
  249. Mud flaps
  250. price for used rs500 inlet manifold?
