4x4 and 2wd HT lead difference?
the 2wd dissy is taller and has a side entry cap, and leads have straight ends.
4wd dissy is shorter and cap is conventional type with lead connections straight up, but because that then gets tight under inlet manifold the leads then have right angle lead ends on.
So based on that it would be difficult to fit 4wd right angled lead ends onto the 2wd side entry cap, and the 2wd straight lead ends would not fit onto the 4wd dissy as the leads would foul the underside of the inlet manifold.
hope that makes sence?
DD
DD
FlashRS
13
31-08-2015 06:02 PM
