Amal valve location / fixing
29-06-2008, 10:00 PM
I've seen a lot of variation and am just rearranging my bay a bit to fit a pre cooler. Just wondered, does it have to be mounted flat and level as they always seem to be from what I've seen?
Anyone know please?
29-06-2008, 10:08 PM
can be mounted any where fella inner wing etc, AS autos do a mount for them but i just made one up
30-06-2008, 10:25 AM
Will work fine at any angle.
30-06-2008, 10:31 AM
anywhere mate as long as you have the wire connected
30-06-2008, 10:38 AM
fitted mine on the side of the airbox, so was very hidden.
30-06-2008, 11:57 AM
Quote:
Originally Posted by
Ryan
& a pain to get to in Germany
30-06-2008, 12:16 PM
yep
indeed its not easy if you want to adjust the jetting on your amal valve
30-06-2008, 12:59 PM
Go for a pro alloy bracket
job done
Luciano
30-06-2008, 06:47 PM
Got one Charlie mate - it just looked a bit big and in your face / in the way to me??
Had the amal hidden under the front lip before this and could keep it there if I angled it - easy to get off too so it will stay that way now I reckon
Learned that the Airtec pre cooler doesn't fit the standard 500 as the pipes foul the crossover pipe. Darn it!!
01-07-2008, 10:59 AM
AndyPen
The very 1st Amal valve bracket when Pro Alloy started off. I gave them some dimensions & they made this....
01-07-2008, 11:49 AM
01-07-2008, 11:56 AM
andy you need a turbo cooler
01-07-2008, 12:01 PM
dont i'll end up with half your car................
01-07-2008, 12:02 PM
More boost Igor!
Mine's still where Ford intended...You'd have thought that the aftermarket coolers would make provision for it somehow.
01-07-2008, 01:10 PM
andy, thats the plan mate
01-07-2008, 10:40 PM
Neat bracket Andy - top job pal!!
Airtec are taking my pre cooler back as it will need modding. Have the Pace one from Build 16 fitted and used the original rs500 intercooler brackets inverted - works a treat. Still no room for the original rs500 rail and mount for the amal though so done a temp job for the moment.
tankybaby66
06-02-2016 02:24 PM
01-11-2015 06:53 PM
mjonathan24
29-10-2015 10:39 PM
Steve Escos
01-10-2015 06:57 AM
Russ Payne
25-09-2015 08:29 PM
