T5 Gearbox
do it yourself if your half handy with a spanner; the bearing will cost between 15-20.
a garage will charge you an arm and a leg to remove a box and refit, its all labour basically - input shaft bearing are fairly easy to do, i done one 2 weekends ago
i can give you a few pointers if need be
Yeah I will remove the box myself, but according to the Ford T5 Manual I need a special tool to fit the new bearing ??
Is this correct ??
Dearo
chowfornow
14
05-01-2019 09:01 PM
