i run in my cossie green with 3 bar map sensor,4x4 intercooler MSD Closed Loop chip,full scorpion exhaust,is it ok that set?or the car it will delay?any opinion,will be help.also my car is 2wd!!
thanks
I would not try to fit that, the front housing is different to cossie one and you would want 360 deg thrusts and a full balance at least, cheapest option would be a T34 2nd hand. Or you would be best to get your own rebuilt properly.
i have already 360o thrust mate,also, as long as front housing need only adaptor for the hose if you mean that about different,i think.
cool in that case your chip would be no good as the flow rate of the turbo will be increased!i would recommend you get a proper ready built T34 if you wish to go down that route and a chip to suite
the best way is the live mapped but it's not easy to me,because i'm not from the UK.
yes a live map is the best way,but if u know the exact spec of your engine stu will be able to do a very very good chip for u!but i would not recommend that turbo kit!would get a proper T34
i don't want to go up with T34,i want T3,as I know the standard T3 reaches until 300hp i think,or I make mistake?
