Another Stupid Question
Is There A Way To Tell Witch Cam Is In An Which Is Ex Or Are They The Same?? As Looking At Them I Carn't Tell Any Difference Between Them.
Thanks
Thanks
thanks
i have 4 cams as i have to heads to build one good one.
i have used the best 2, one with scrolls as the inlet and one witout ext but both num are lyd4
and on my 2 other cams the num are ldy1 and the other ldy5
Cossiemodo
Fae the Dale
Not a stupid question when you dont know the answer
I'll be keeping an eye on this thread as i'm unsure too.
Reason being i bought a stage3 sapph and was unsure if a diferent camshaft was fitted or just the standard.
Going to replace my cam followers shortly so will have a look then.
2wd and 4x4 cam shafts are different aswell eh??
