MAP Sensor Vacuum Pipe Length
perhaps for unmodifed engine
if you change injectors turbo
put swedish plenum ...
do you think it's still important to have 280mm ???
I relocate my MAP with the swedish plenum and lengh will be 400mm ; I will just give the information to MSD
most important is to have a rigid hose (not silicon hose !!)
Colossal Pervert
I can't really see why it HAS to be a certain length, within reason. I think the latency you'd incur by doubling or tripling its length would have no noticeable effects.
find this on the site :
length and voltage on the MAP 3B
280 MM HG 0.66-0.76 volts
500 MM HG 1.36-1.45 volts
650 MM HG 1.81-1.91 volts
750 MM HG 2.11-2.20 volts
and the value volt / pressure for the MAP3B
Voltage Pressure
mv Kpa
0 0
250 17
500 33
750 49
1000 65
1250 82
1500 98
1750 114
2000 130
2250 146
2500 163
2750 179
3000 195
3250 211
3500 227
3750 243
4000 260
4250 276
4500 292
4750 308
Voltage Pressure
mv Kpa
0 0
250 17
500 33
750 49
1000 65
1250 82
1500 98
1750 114
2000 130
2250 146
2500 163
2750 179
3000 195
3250 211
3500 227
3750 243
4000 260
4250 276
4500 292
4750 308
DixieTheKid
11
06-06-2020 11:20 AM
wheelwizardrefurbs
24-09-2015 08:35 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
