torque settings??
torque settings??
can anyone tell me the settings or where i can get them from for the cam caps and arp stud an nut kit for a 2wd thanks
spelling is not my strong point
Block cracking is caused by people not cleaning out the holes that the studs go into, they contain old congealed oil, always clean these out and run a tap down them.
When I did mine I measured the depth of the holes, which were at least 4mm longer than the studs themselves, I just screw in finger tight, then a tweak with a grip on the stem of the stud, they have a shoulder at the bottom anyway to prevent them from going too far in, personally I don't beleive any block is cracked by the application of studs, more likely head trying to lift from too much pressure.
