cosworth 2wd hubs
cosworth 2wd hubs
Does anyone know the size of socket i will need to remove the big nut on the end of the shaft / hubs , i measured it to 41 mm but want to check before i order one .
Thanks Travis .
Thanks Travis .
From memory 41mm sounds about right from when i had to get one, as long as you have measured from flat face to oppisite flat face it will be right and get impact obviously
FlashRS
13
31-08-2015 06:02 PM
Jack and the Beanstalk
15-08-2015 04:27 PM
