kent cams
kent cams
Hi everybody,i would like to ask you about kent cams,which are the best for cosworth cams?,with greens,3 bar map sensor,etc...also if i fit new kent cams need to use another chip?now i run MSD closed loop! thanks a lot.
Cossiemodo
If you're running Greens, is a cam the best upgrade path for you anyway? You could, for instance, go Greys + suitable map/chip, and get lots more power, without the extra hassle and expense of cams.
Just my 0.02 and I'm often wrong
If you alter any cams you will need another chip, as fuelling will be totally different which is the idea of the cams.
With what you are using std cams are perfect, I would myself not change them up to at least 400bhp.
Mc5506
05-10-2015 09:57 PM
