Remove transfer shaft from 2wd cossie
Old 14-07-2008 | 11:09 PM
Thanasis's Avatar
Thanasis
Default Remove transfer shaft from 2wd cossie
Hello everybody,can anyone explain how can to remove the transfer shafts from 2wd rear diff?
thanks a lot
Thanasis
Old 15-07-2008 | 06:26 PM
cossie604's Avatar
cossie604
Do yor mean the out put flanges on the diff? If so, then its dead easy! Remove the back plate, rotate the diff until you can see the sun and planets and you'll see the two big C cips that are holding the flanges in place...I find the easiest way to remove these is with two good sized flat blades screwdrivers and just push both sides of the clip down at the same time.
Old 16-07-2008 | 12:55 PM
Thanasis's Avatar
Thanasis
Many thanks my friend,
Regards
09-10-2015 08:38 PM
FlashRS
13
31-08-2015 07:02 PM
29-08-2015 09:16 PM
Caddyshack
15
04-08-2015 09:50 AM
lockie
31-07-2015 11:03 PM
