- Original A/C on 3dr Cossie??
- would this fit???
- Stupid Clutch Cable Question
- Am I the oldest boy racer on here? Officially warned now
- Turbo hose fitment for GT30
- cosworth t3 turbo help
- how much is it worth????
- any one got a relay diagram for the fuse box?
- Sapphire rear shelfs?
- car stalling at junctions
- 4x4 transfer box oil
- front coilover fitting?
- Altenator tested OK but light still on after reving - SOLVED
- cossie loosing powersteering oil
- dump valve
- diff gasket 2wd Cosworth
- Sierra Cosworth 4x4 Display problem
- Grey relay in 2wd saph pass footwell?
- Yellow relay in saph fuse box (supplies black/yellow wire 4 dash)
- Faulty map sensor ?
- ARP Stud and Nut
- 4x4 saff mongoose center section, same as escort cos?
- Bugger, split fuel pipe. Aeroquip?
- Engine/Radiator/Bumper Fitting
- My Saph. An update on loads of little bits. 13/04/15
- Thoughts on misfire anyone?
- Starting problem?Updated stil not working
- Favour Request
- Where can I get longer exhaust manifold studs from? **Got Some**
- bumper removal on a saphhire
- Replacement fuel lines.......
- Uprated 2wd Gearbox Mount
- What are the best value for money pistons
- brake lights
- 4x4 to 2wd (UPDATE) 17/01/10
- 3dr heaterblower cover
- T34 Turbo
- Putting an estate exhaust onto a sapph cossie
- Problem when the engine is hot
- rare as ??lol
- vibration after changing to T5 box
- Seized bottom pulley
- 2wd or 4wd head. how do you tell?
- rear strut braces.. triangle one.?
- t5 worm drive
- 4x4 front legs on 2wd?
- Finis code TCA ball joints threaded type?
- MAP readings?
- finally plumbed my boost gauge in and im running a wopping
- 4x4 camshaft o-ring, where should it go?
- Gearbox Problems
- 4x4 Gear Box - What to do
- More noise
- sierra xr4x4 electrical problems
- saff 2wd driveshaft
- Electric window wiring diagram wanted
- rocker cover..repaint
- Fuel pump rewiring?
- t25 turbo question
- 4x4 saff quick question airbox / cone filter
- solid brake pedal.....
- Has any one got for sale.....
- What Guages to run?
- fuel regulator
- Wiring diagram
- battery sizes
- Door mirror units
- Starter wire ?
- temp sender on 4x4 saph
- Spark Plugs
- Problem with brakes. (3 door)
- rs500 D reg????
- lighten flywheel on 4.44 cwp?
- Coil Overs
- 6 degree rear beam now fitted & setup
- Noises
- How much is a 3dr cosworth very rusty worth with a brand new coswoth shell
- Alloys wheel lock nut cover
- wath options for bigger turbo on 4x4 sierra
- Can anyone help please
- Buzzing sounds...
- Can a ISCV cause idle revs as high a 2500 rpm??
- 4x4 inner and outer front Cv's are they sided?
- Dip stick tube
- anybody scrapping a sapphire shell??
- Diff pinion nut?
- 4x4 sapphire tracking?
- Petrol tank help please!
- Will a 2WD rad fit a P100
- DIY Stage 1 Chipping on a 3 door
- tachometer
- Buena Vista Hill Climb Report and In-car!
- intercooler to throttle body, RS500
- BurtonPower's "COSWORTH YB LONG HEAD STUD KIT"
- how to tell if rs500 spoiler is genuine ?
- Oil temps
- Best place to plumb in a fuel pressure gauge?
- Turbo Rebuild
- Big Brake conversion 2wd....
- paint code for lattice wheels
- Alternator question !
- Act gauge
- Track ready Sapphires
- SEC's coolant alarm
- mt75 box issues
- How to remove a 3 door loom?
- Cosworth stage 3 fuel pump?
- cosworth woes
- 4x4 front door central locking, which wires do what?
- 4x4 front hub drive flanges
- 205 block problems!
- Where to get a SECS monitor for my 3 door?
- Cosworth not running right
- AbS light staying on!
- Sierra Loom
- 2wd running badly
- Sapphire 4x4 boost issue
- 2wd turbo issue ?
- Anyone uprate ARB to a 3dr
- ignition switch question
- Hit & Run..
- compbrakes
- wireing problems on a 2wd
- comps
- 2wd bottom end, balancing[how much]
- 3 bar map sensor codes
- 31 actuator
- Lenso BSX wheels on a 3door
- annual milage??
- Bayjoo spec Leda springs
- Uprated diff mount/hanger
- What a fool.
- rev counter for coil pack
- sapphire cosworth headlights
- 2wd inlet mods/ upgrades?????
- 3 Door indicators
- Cold Oil Pressure
- Genuine Cosworth headlight
- dunno what to say....
- rev counter problem
- converting to p8
- wastegate
- fuel pump shut off switch
- afr readings?
- Saph offset?
- Colorcode
- Front ARB
- 2wd Saph
- oil cooler
- Saff 4x4 engine rebuild
- sapphire rear bump hanger bracket
- Beware of this car!!!
- how many silver saphs were made?
- Are Scorpion backboxes restrictive....
- VSS on T5 box
- Breather
- Replacement/repair Sierra inner and outer arches.
- Rs500 Copy Grills
- Removing saff 4x4 engine
- Rear Diff Pinion Oil seal
- 3 Door rear 1/4 window trim
- Changed the fan belts today (lucky i did)
- et33 offset on a sapphire
- Hose gone again...
- Viscous Limited Slip Diff
- Who else reckonises this? Bad chip after headgasket change..
- brake problem
- T5 box inspection plate removal?
- Rs500 front spliters
- power steering
- Actuator
- What torque in NM?
- Sierra Locks and Ignition.
- anyone had dealings with these bushes?
- turbo choice
- aeroquip size
- cam bearing cap stud thread loose!
- blacks or greys..??
- Revs to 2500 then cuts out?
- cosworth alloy side skirt clips
- Sierra Cosworth 2wd rear new brake caliber pistons, where?
- Oily film in the header tank.
- trouble with stage 3 and perhaps msd eprom
- roller bearing T4
- 4.44 cwp match to what turbo
- Standard clutch
- rough idea on price..??
- Running rough when cold
- Sapphire cooling fan relay
- leak down?
- good tappets?
- 3dr boot rubber etc?
- 2wd driveshafts on a 4wd rear end ?
- How to Crackle Black My Rocker Cover
- Common places for 4x4 to leak gearbox/diff oil
- bilstein coilovers
- 3.38:1 diff in cossie
- Sierra Sapphire Cosworth Jacking point covers
- Ford 2007, 2040cd and amp wiring?
- Front Springs
- Another Sierra Cosworth Forum
- Fuel pressure setting...
- Light Greens
- A great find in a barn
- Best leather treatment for saff cos
- how to identify cams
- help wheel choice
- What chip is this
- on board computer died
- What is this
- 3dr ECU wiring cont.
- Inlet manifold earth wire?
- How much Oil does a T5 Gearbox whole?
- core plug came of while been dyno
- Cossie cuts out?
- Bearings, would you change them ? (HEAVY pictures)
- standard rear amber lenses saff?
- snapping osf driveshafts???
- GEARBOX?????
- rust near bonnet hinges?
- saph rubber door strips
- manual clutch adjustment
- Can i adjust the clutch cable on a 2WD saph?
- What colour is the window tint on a 90 black 4x4
- clutch cable and rear main oil seal?
- front bumper brackets
- 4wd to 2wd conversion
- how much?
- New Sierra Forum
- escos wheels on 2wd
- sounds like a f***ing bus!!!
- Amal valve connection & no boost?
- 3Dr Questions
- cossie 4x4, which fuel pump???
- Front disc sizes 2WD / 4X4
- Leather interior
- siemens injectors
- Change pinto for cosworth
- Propshaft
- Datastream enabled ECU
- can you still buy rear quater glass rubbers ?
- not fueling 4x4, please help...
- Rear wheel bearing
- Rock hard brake pedal
- standard TCA's still available from ford?
- 380-400 bhp
- Mates 4x4 saph-No spark???
- How much power
