vibration after changing to T5 box
Hi,
i have just converted my saph from the mt75 gearbox to the T5 gearbox.
all is fine untill i reach over 80mph and let off the throttle, when there is a vibration that shakes the car. it is eadily seen through looking in the rear view mirror as everything is vibrating.
all was fine before i changed the gearbox, have checked to make sure everything is tight as much as i can but cannot figure out where the vibration is coming from, as its is fine below 80mph. it does it if i accelerate slowly to over 80 or if i do it quickly.
any ideas would be much apprecitated as have to go on the motorway tomorrow and dont want to cause any damage if i stry over the speed limit.
Adam
Adam
What do you mean shims I have never had shimes under the centre support.how thick should the shims be as I can make some up?
Also what is the best upgraded gearbow mount have looked at the vibratechnic ones but are there any beter ones.
andrewmctiernan
08-09-2015 03:05 PM
