cosworth woes
cosworth woes
hi all
whent out in the saph last night an it has developed a bit of a problem. its a bit difficult to explane but al giv it ago. basicly it drives fine off boost but when it comes on boost it will pull for a couple of seconds then it shuts the throtle completely. it doesnt cut out just backs off, if i keep my foot in it will boost up again then back off again. any help apreciated ment 2 b of to coomb next sat
cheers daz
cheers daz
tabs dont know bout fillter i havent changed it but dont know bout previous owner?
kossienutter well al be going with or with out the cos but if it makes it al b on south lincs stand
cheers 4 the advice peeps think al get it looked at sounds like it could b a million things
cheers daz
cheers daz
sorted
it was the vac hose from fuel reg. some how it managed to come loose even with clips on each end cheers 4 the help thoug guys roll on coombe
daz
daz
cosworth gimp
if its a 2wd car you have mate and the vac pipe -fuel reg has come loose
MAKE SURE YOU CHECK THE HOSE THAT CONNECTS THE REG TO THE RAIL ALSO
MELTDOWN WAITING TO HAPPEN IF ITS SPLIT OR LOOSE TRUST ME !!!!
just make sure you check it too
t4 - will do mate i dont want that
andy - same 4 u mate
glenny - yea specialy stupid little things that arnt obvious but can cause serious problems
Adam Graham
06-09-2015 06:04 AM
