What torque in NM?
Job done ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
Had to go out and buy a 230v Impact wrench to shift the pulley bolt!![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Pulley itself came off no bother. The belt took about 2.5 hours to do, thats including draining the coolant off, dropping radiator, underbody tray, timing belt cover and new tensioner.
The belts Ford supllied me with for the Alternator were to small so only good for Power steering.
I had to put the old belts back on and ones cracking and missing a tooth![Confused](https://passionford.com/forum/images/smilies/icon_confused.gif)
Best get to Halfords soon
Be VERY careful when using a puller on these, the thing you should have done with the pulley off is to take out the woodruff key and apply valve lapping paste to crank nose and lap a bit, this would mean no more getting stuck, my pulley can be slid off with just moderate hand pressure.
That way in future just remove fans, and can do it all easier no coolant issues.
DavidK
27-09-2015 02:55 PM
