Best way to be 100% sure is check part numbers, I can't see why they would be any different, the 2wd cossie hub flange is no thicker than a std 2wd one I do know, as I've measured them but never 4wd.
Yes they are the same, the only difference is the actual driveshaft is longer on the normal non cos 4x4 ones but these can be swapped over or kept as they help if the car has been lowered.
There are probably no other Ford hub flanges that are same as 4x4 Cosworth's? As for example mk1/mk2 Mondeo front hub flanges look very much the same, but surely they must have slightly different dimensions?
Lol,that was a while ago,
as said they were the same,
they do seem to wear where inner bearing race sits,think I've replaced them a couple of times over the last 15 year,
Colin
