comps
FROZEN WHITE FRS No2676
1 Post
Hi mate like i said on the phone today the wheels must be wrong offset no way should u be hitting it with a hammer thats gash, mine are the same 1992 saph 4x4 8x 18 et 35 215 35 18 toyos bilstein suspension fit no probs check the pic.
Location: guernsey,c.i.. a rip off island , full of drunks
you dont seem to be having much luck lately .... like my brother says ,, i would not hammer the struts because it is rough and you want to do the job properly ... you will find coil overs will give a lot harder ride ... which might not be so good for jersey roads ... your car ,, your call .. seems strange yours dont fit ,, like ben porter says if u have konis looks like they have changed them ... dean has bilsteins.. dont know what to say mate because spacers aint ideal either ... you will sort it .... regards mark
1 Post
I cant believe what some are u are saying hammer it cut it best i dont buy a car off u lot it will be two cars welded together even Dick Turpin wore a mask!!!!!!!!!!!!!
had the problem on mine and found out,that some dampers have another desing of the cup. The origlinal ones will rub on the wheel and koni ones gave a lot of clearance.
But as said, you can mod the old ones to make the fit
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
