solid brake pedal.....
any one no what would cause the brake pedal to be solid brakes still work as does the abs and no lights are on the dash. you have to press realy hard and it only moves abit.
thanks
(spelling)
thanks
(spelling)
Resident Wrestling Legend
there are 3 of them
either 2 green and one purple or 1 purple and 2 green ones
should be under the passenger side glovebox area by the transmision tunnel on a littl ebrakcet
whats happend is that the pump has pumped up tpp mush pressur einto the system so it needs releasing
it might need a new pressure switch though, in which case, you migh tbe beter off looking for a whole new pump assembly as the fluid tend to corrode the innares and they strip the threads from both the casing and the valve
SIERRA RS 4X4 COSWORTH
there are 3 of them
just had a quick look and i have 1 yell 1 green and 1 purple relay and could only swap 2 as one has 5 pins the other 2 have 4, and it didnt make no diffrance to mine. but what i did notice is that if i pumped the pedal when the pump was still running it was softer and i could push the pedal down more, then it got harder and harder till the pump stoped.
tried a purple relay out of another saff[with working abs system] same part no as mine and my abs light came on and break fluid level warning light came on aswell[mine has never done this].will go to fords and get 3 new relays .
NO !!!! Put new green reley in from Ford , 2x purple releys are on back order . abs sensors tested range .9 to 1.1 all four so they seem OK. Pluged in snap-on fault code reader and melted my wiring loom to the abs [ lucky didnt set my saff on fire] some twat had back wired one of the relays to put out the abs light . getting a new abs wiring loom / ecu got new sensors already but mine seem ok [so will keep as spares] what a carry on !!!!!
competant bodger
had this once with my xr4x4 caused by sitting in traffic for an hour with my foot on the brakes....DOH!!! pedal went rock solid and took serious effort to stop allthough luckily after i got home (and felt the pump and servo which were damn near glowing lol!) after letting it cool down all was fine. this probably wont help you with your fault but may help other sierra abs owners from doing the same dim witted thing i did lol!
