Seized bottom pulley
Yep as said. I had the same problem.
I bought an impact gun from machine mart for £50 450lb
cam straight off and it does'nt chew anything.
Shame you were'nt local I couls have popped accross and whipped it off for ya!
Get on That!
use a breaker bar with an extension put it in gear and then get some1 to put foot on the brakes and hang off the bar had to do this many times it will eventually loosen.
also soak it in penetrating fluid 24hrs before and this should also help
I think one of the major problems is that when you try to loosen it in 1st gear is that there is so much movement on mounts etc and engine twisting before it actually puts force on the bolt it is limited by this in the force applied.
I always put the car in 5th gear, and do from above, with rad pipes etc out of way(if convenient) you can get more swing, use extension just to make easier, I use this on my 4 foot ratchet a 3 foot extension, but so I have about 5 1/2 feet in total.
SMILER258
28-09-2015 09:04 AM
