SEC's coolant alarm
Last Time, Get Off PF FFS
strange? Have you check the wiring for the temp wire. Some people say take the wiring plug out the back of the monitor for a few mins for it to sort reset. Check the connection at the ecu end of the wiring
You've got an open circuit on the connections from the monitor to the ECT sensor. Either the sensor is poked, or the wiring somewhere - how did you make the connections onto the ECU plug?
