Cosworth not running right
Last Time, Get Off PF FFS
hi guys put this in the technical q-a aswell.
got a slight problem. when i want to come on boost above 10 psi the car begins to stutter and pink out. im am going towards the fuel pump not getting 12volts idea.
am i right or could it be something else?
the boost doesnt drop of.
its a stage 1 4x4. plus it only does it from third gear to 5th cause obviously there less strain on the engine and pump in the lower guys i guess.
__________________
__________________
Yes dead easy, make sure you get new copper washers for each end though, as old ones go hard and like leaking when disturbed, note flow direction arrow as well!!
big_Rad
15-09-2017 09:36 AM
