rev counter for coil pack
21-06-2009, 10:29 PM
Can't remember the way to convert a standard rev counter to read the coil pack ?
22-06-2009, 05:51 AM
All I did was use a plug in module, between ecu and tach, £30 job done, been 100% perfect ever since.
22-06-2009, 06:00 AM
PassionFords Creator
Do you have details you can post up Tabs?
Failing that, I can supply you a diagram on how to wire it yourself, but a doubler module sounds potentiall simpler.
22-06-2009, 07:36 PM
would like to know this cos i fancy coil packs, just was unsure about rev counter
23-06-2009, 05:05 PM
Quote:
Originally Posted by
Any contact numbers for this item tabetha ? Many thanks
23-06-2009, 05:15 PM
I've got a stack st200 tacho.
23-06-2009, 06:08 PM
I just bought a unit from Emerald, goes between tacho and coilpack, to do the convertery bit, sure I'm still using coil feed to tacho not the ecu(aftermarket) feed, will ask me loom na tonight and post up and pm stu, when more info.
23-06-2009, 08:45 PM
TT T38 Power
Stu @ M Developments
The diagram Stu supplied to me after fitting the coil pack works fine on my car.
Steve
23-06-2009, 11:00 PM
cossie4i
Steve
Any pics ??????
24-06-2009, 01:22 PM
K***LMT
24-06-2009, 02:08 PM
Haven't seen dave yet, as someone(off here!!) is late for mapping, so think dave's sunbathing, but going down in a bit and will ask.
24-06-2009, 04:45 PM
TT T38 Power
cossie4i
Steve
johnyjn
Any pics ??????
Sorry, the diagram got binned after fitting.
Steve
24-06-2009, 05:04 PM
ive got this problem on mine. was told that if i fit inj clocks it will work? anyone confirm this?...
24-06-2009, 05:10 PM
Passion for Fords!
its a very simple mod on the 4x4s
24-06-2009, 07:29 PM
My car is running a pectel t2 ecu do they have a signal feed coming out for a rev counter ?
02-07-2009, 09:58 PM
15-07-2009, 10:00 PM
hay up john can u not run it off the tack wire that would usualy go your coil as it would still use the tach wire for wiring up the coil pack? thats all ive done with mine and works perfect on a grp a coil?
01-11-2015 06:53 PM
A.t.p
23-10-2015 07:54 PM
jameswrx
Modellers Corner.
17
09-10-2015 08:26 PM
07-10-2015 12:56 PM
KennyWelsh
Ford Focus (All Models)
13-09-2015 08:28 PM
