View Full Version : Ford Escort RS Turbo
  1. Few n00b ZVH questions
  2. Water temp sensor
  3. Opie Oils Now Stock Ferodo Brake Products
  4. Anyone know anything about this company?
  5. Brand new header tanks?
  6. how many black s1 where made ??
  7. my new toy
  8. Where to mount a oil cooler?
  9. Mk3 five door
  10. S2 mtx selector cables
  11. no battery light
  12. are 2.0 black top con rods same as the 1.8 rods
  13. Brake Compensators / ABS Removal
  14. Got some new wheels for the s2 ;)
  15. low compression
  16. Overheating ?
  17. Euro optional extras
  18. aftermarket gauges probs
  19. Rear disc kit
  20. B+M shifter strong vibrations, clutch judder!!
  21. fuel pump
  22. Zetec cams
  23. How much for
  24. bad starting when hot
  25. s1 rs turbo wanted
  26. best way to sell an rs turbo :(
  27. More Power?
  28. Engine temp Sensor on ebay
  29. OFAM ecu Any comments?
  30. Pressure plates
  31. S2 speakers
  32. Which turbo for efi turbo xr3i
  33. what clutch?
  34. S1 metering unit vaccum pipe outlet to amil valve?
  35. strut brace
  36. back wheels clunking
  37. s2 boot struts
  38. Can a 1.8 zetec be bored to 2ltr?
  39. Ford Escort RS 2 Full Resto - My first attempt
  40. Bonnet alignment
  41. GPA coil rewire loom
  42. fuel rail quip fitting
  43. do you know this car
  44. ZVH starter motor
  45. efi throttle pedal and cable
  46. Quick EBC brake pad question
  47. Interior Light (bulb type?)
  48. Series 1, L6 with w/s Rev counter help required.
  49. megasquirt loom protection
  50. no speedo????
  51. S2 f200 tel
  52. Ford PCD?
  53. roof question
  54. s2 metering unit
  55. Stage 3 t3
  56. Ha my car damaged
  57. 3dr cossie rims on rst...
  58. S2 bumper/ rs500 splitter
  59. Speedo sensor removal
  60. no fluid at rear drums??
  61. blacktop alternator setup?
  62. s*#t heaters??
  63. Aftermarket Tacho In standard location
  64. cold start sensor
  65. Is this genuine
  66. escort temp sensor
  67. fuel pump always priming
  68. indicators
  69. RST relay questions
  70. MFI Fuel Pipes
  71. Replacement wheel bolts.. With link...
  72. Cold heater
  73. Front Wiper Arm Nut Covers
  74. unplugging ecu ofac
  75. dodgy starter?
  76. Cooling Sysem Upgrade.
  77. Uprated GPA coil
  78. chargecoolers...
  79. Boost Pressure PROBLEM!!! HELP!
  80. What drop?
  81. Fitting Brembo's?
  82. Picking my s2 up saturday :)
  83. ebay help
  84. Rs onion getting hot.
  85. Gear Change pops!?
  86. MK3 Escort in Restoration project rs turbo conversion
  87. Looking at buying an s2
  88. Forged Pistons
  89. Just brought myself a nice 90 spec :) (now with pics)
  90. Spraying the underside after wax-oil?
  91. mates escort rs turbo keeps cutting out?
  92. what is the best head gasket to use 4 a escort rs turbo s2 engine 200 bhp plus
  93. What is this
  94. where to get a new standard cam?
  95. s2 fuel gauge problem
  96. Fitting S1 arches and skirts to my S2
  97. 3i to turbo
  98. people who have converted to efi
  99. Shropshire rs owners
  100. sitech headbolts zvh
  101. EFI block
  102. people with carbon roof/welded sunroof help please
  103. Cossie 4 pot calipers
  104. Mk3 ghia 5dr brake upgrades
  105. Xr3i masters
  106. ZT Thermostat Housing
  107. Best spark plugs??
  108. Modifying Bailey Breather ?
  109. 1.8 bottom end for goin zvh
  110. S2 RST Springs in an Estate?
  111. Cutting out problem
  112. Bosch thermo-time switch.
  113. S1 Drivers door won't close!
  114. buying a black s2 rep xr3i mfi cabby very soon!! what to do with it
  115. Best place for exhaust wrap?
  116. New metering unit
  117. set up?
  118. sunroof tray
  119. LSD?
  120. Piston identification,
  121. finnis number?
  122. Deposit put down on Series 2
  123. What bushes?
  124. anybody know what spec turbo is?
  125. monroe suspension
  126. Rebuild panels
  127. best way to take the engine out
  128. want polybushs, where from
  129. Ford racing temp gauge
  130. miss fire
  131. battery tray welding in essex?
  132. ib5 gearbox
  133. Rear Cossie brakes on s2
  134. Rear disc conversion
  135. clutch
  136. Not having a good day
  137. Fitting cossie plugs to a zetec head
  138. Cleaning samco
  139. What colour for underneath of grey S2 RST
  140. my brand new alternators charged at 16-19v! swapped it for another one n stil same???
  141. xr3i brake servo reservior bigger than the rs turbos?
  142. non abs reservoir
  143. MFI to aftermarket enginemanagement conversion
  144. master cylinder
  145. powerband
  146. oil pressure and temp
  147. Free Shipping on ALL UK mainland orders over £40
  148. Best tuner / set up in Northwest??
  149. Parts
  150. Sump sealant
  151. Engine swop
  152. series 2 fuel problem
  153. st170 calipers
  154. ka pulley on rst
  155. Rover inlet manifold
  156. What clutch?
  157. Cold start valve..
  158. Need help
  159. Anybody Got An RS Turbo LSD Gearbox For Sale ?
  160. xr2i efi crank
  161. Newman cam question
  162. HIDS
  163. bosch mfi metering unit help?
  164. front outer door weatherstrips
  165. twatting spax top nut??
  166. Is this the clutch? Pressure plate? Or release?
  167. just bought a white series 2 any ideas?? now with pics!!!!!!!!
  168. Rebuilding metering unit
  169. St170 conversion?
  170. braided brake lines
  171. fans?
  172. smoking rs turbo
  173. is it legal?
  174. coolant temp sensor
  175. Brakes
  176. rebuilt it and now running rich
  177. New engine pics, and some different questions :)
  178. struggling to boost like it used to??
  179. gearbox mounts
  180. Body kits
  181. Another abs thread
  182. st170 brake conversion
  183. s2
  184. strut brace
  185. Gearbox crunch twickenham
  186. Cams
  187. Show Us Your Track Prepped Escorts!! Pic Request!
  188. megasquirt help please
  189. show us your turbos!
  190. what power/bhp can i get out of my spec guys
  191. G530 VTW
  192. metering unit
  193. H REG RST I Bought With Rotten Sills
  194. mk6 escort sunroof replacement
  195. disconnecting abs
  196. idles low sometimes
  197. Rebuilding t3
  198. bloody sunroof!! can anyone help!
  199. Help me pick a colour!
  200. RST over fueling?
  201. Can a rear mount starter zetec block be modded to fit an Rst block?
  202. Gearbox question
  203. cut out around 10times on 6 mile journey n now ok?
  204. Discs and Pads on Std RST Brakes
  205. New Airtec Product Offer!
  206. Wiring Up A Horn On Escort MK4
  207. s/s fuel pump cradle???
  208. engines dies when warm? could be this...
  209. Escort cosworth wheels
  210. Ignition switch
  211. does s1 rear seat fit s2
  212. Megasquirt-boost control question
  213. threads gone AGAIN?????
  214. Escort RS turbo oil pressure and temp
  215. Usual suspects, what to look out for on rst engines??
  216. S1 SERVO
  217. MTX75
  218. smoothing bumpers?
  219. overbore advice
  220. price tag
  221. rise in hp via boost + ignition issue.
  222. is this real
  223. series 1 rad
  224. New Product Range! AIRTEC
  225. Where to get rear brake discs adapter bracket?
  226. st170 head
  227. new crank
  228. Piper cam timing RST
  229. Anyone from my area?
  230. escort mk with rst running gear faq
  231. Revs drop up and down after around 5 mins then cuts out and won't start
  232. cosworth Mahle pistons
  233. Bottom Pulley Dimentions
  234. What alarm
  235. Orange Poly Bushes
  236. Has anyone on here owned my car??
  237. runnig rough
  238. is there any parts worth grabbing off my mates mk6 escort that hes scrapping?
  239. Just general info needed
  240. Rs turbo measurement (length etc.)
  241. performance tires in 195/50/15
  242. converting a blacktop 1.8 foucs to turbocharged - ?? options
  243. Efi question
  244. Anybody used these gauges??
  245. Few Efi Questions..
  246. S2 help anyone ?
  247. External wastegate..
  248. series two rear spoiler cap?
  249. actuator wound up sky high?
  250. Tailgate Boot Struts
