Cooling fan always ON
Hi guys,
I noticed my fans are going on just after 5 minutes my car started, both fans are running low speed all the time.
I just got the car a few months ago and noticed temperature on the dashboard stays pretty low all the time, like the car never warms up, It is situated more or less at the quarter of the screen temperature, is it normal operating on the RS? sometimes cars are different, I thought it should be in the middle.
Anybody got a picture of sensor level on dashboard at normal temperature?
FYI: timing belt, hoses, thermostat and cooling liquid are new
Thanks for your answers
Cheers. Roland
Cheers. Roland
The fans should not be on, possibly a faulty fan switch.
The Escos has a two speed fan system, I am not that familiar with it but will be fairly basic, probably a low speed and high speed relay.
The gauge sounds about right, mine sits near the bottom and at the most in the middle in hotter weather.
You really need an IR thermometer to accurately gauge the temperature.
Martin
Martin
Hi Martin, thanks again for your reply.
I assume you speak about the switch on the radiator that quicks in at a certain temperature right?
I will check the relay that might be locked on ON position
Hi,
Sorry for the inconvenience, I thought the RS turbo for the cosworth, sorry about that.
I will move the thread if I can or else, will close this one and create a new one
woodz77
21-03-2009 08:38 PM
