do erst's (or any other cvh application) have oil squirters?
Do the escort rs turbo cvh motors have oil squirters? you know, piping that is bolted on the bottom of the block downstream(pressurised) from the oilpump that sends oil thru piping that has holes/fittings that squirt the bottom of each piston up into the cylinder bores? i am from the states and if you guys have CVH or zetec motors and oilpumps with this capability please let me know, otherwise a custom setup is in works.
the mazda BP motors in our escort GT's over here do have this and it is very good for turbo applications.. keeps your conrod to piston bearing and the top of the conrods cool and less likely to fail in high heat/high boost environment, especially with our stock cast rods!
as far as know, my cvh is the only cvh with under piston oil spray jets. It was custom made and designed to only spray at peak oil pressure. The later zetecs had spray jets as standard.
