Mfi to efi fuel lines
Wish I had more time!
Morning everyone,
I know it’s probably been covered a million times but I can’t find it anywhere, I’m in the process of converting but not sure what I need to use fuel side in regards to old accumulator etc and the frst fuel rail has the end on the pressure regulator and then a screw on type at the other end, some detailed advice and maybe some pics would help me out a lot so i can get this all buttoned up. Thanks in advance
Blake
Blake
tank to pump
pump to start of fuel line
end of fuel line to filter
filter to fuel rail
other end of fuel rail back to fuel return pipe
other end of return pipe back to tank
ideally you want a pre filter on the pump and a post filter
filter to fuel rail
hi mate thanks for the reply that helps a lot, I’m assuming filter to fuel rail is to the regulator then the other threaded end is the return?
I moved my fuel filter to a bracket mounted on the steering rack so I could get petrol running down my arm every time I have to change it🤣🤣
It was to clean up the bay and hose routing. 😁
🤣🤣 I do like the smell of petrol not sure about using it as a cologne though! I was thinking of trying to mount somewhere inconspicuous I’ll have to look at some options, have you got a picture of yours?
I didn’t like the filter on the inner wing with the hoses looping around the inlet.
thanks
Blake
I think they are M14 & M12 to an6 from torques.
