Clutch/pressure plate or release bearing Noise MT75 RWD Sierra Gearbox
Old 10-06-2021 | 08:20 AM
Bren1977's Avatar
Bren1977
Question Clutch/pressure plate or release bearing Noise MT75 RWD Sierra Gearbox
Posted in the incorrect location. Now moved to where it needs to be
Old 10-06-2021 | 08:36 AM
haz87's Avatar
haz87
Clutch cable isn't going to make it pop out of gear. BTW WD40 isn't a lubricant, its a water dispersant so I'd probably get something more suited to the job in there regardless.
You've posted in the RS Turbo forum rather than Sierra, but its probably worth stating exactly what oil you've put in there as I know these boxes can be fussy. When was the oil last changed? Putting a flush through it may well have shifted something somewhere you don't want it to be. Either way, with that mileage you're lucky that its only just starting to show signs of wear. Coming from a Ford BC Gbox owner, anything you don't need to change monthly is a blessing
Old 10-06-2021 | 08:43 AM
Bren1977's Avatar
Bren1977
Red face
Damn I totally missed the fact i posted in the wrong section! Maybe it should be moved to the Muppet section for making this wrong location post :P
drl
22-11-2010 06:53 PM
stu21t
11
17-04-2010 04:36 PM
stuboy
05-12-2009 07:24 PM
dominikrs
16-08-2008 07:45 PM
Quick Reply: Clutch/pressure plate or release bearing Noise MT75 RWD Sierra Gearbox
