Wasted spark coil pack
Wish I had more time!
Morning,
does anyone know of the standard fiesta Rs turbo coil pack is wasted spark or do you have to buy a specific one?
cheers
Blake
cheers
Blake
The Ford coil packs didn't have an ignition amplifier. So when your ECU doesn't have one, you'll need either an amp module or a coil pack with a built in amp.
My mapper recommended a VW coil pack if you want one with a built in amp but I don’t know from which model.
You can also use an EDIS module. There's been some used as a standalone ignition system with a built in ECU and some that were just an amp.
The VW twin coil pack was probably one like the NGK 48010, used in hundreds of Audi/VW/Skoda/Seat vehicles.
Thanks for the replies, I have purchased 2x cosworth ignition amplifiers which the tuner put on my list of find it items, so with that in mind do I just get a normal coil pack?
muz
35
23-07-2016 11:10 PM
