Airtec Radiator Mounting S2
Evening all - has been somewhat 9 years but car is being slowly rebuilt, but when offering up the radiator with the new turbo and waste gate etc I can’t quite see how it should mount correctly, i have the IC with twin fans to mount thereafter, which has come with some mounts to retro fit to the Rad. Has anyone simply a pic of theirs in position? It’s the ally 42mm type?
thanks all
thanks all
slammedorion (28-01-2021)
Thanks for reply Kev Have had some nylon bushes made up for rad mount, I didn’t realise or remember how the rad sat, at a slight angle etc. Have it all loosely In position, just need to sit the fans in place.
Andy_andyc (03-02-2021)
Nice one - it looks like they are pretty much identical positioning with fans in between. I know it’s going over old ground but just to confirm with you, I can see that bumper will need work to fit snug.
is that a Zetec block behind?
I have had bumper on its has about 4-5mm clearance., intercooler is artec not slimline. Mounts bolt on inside of front panel.
raptor?
I have Edge protection to fit around the valence, and can tweak the position as the hose alignment needs some tweak. I have the foam to seal the rads too so will have a proper play when I get a chance
I’m after a ZVH long block now to build for this once it’s running
raptor?
why is you intercooler mounted on outside of front panel, has your car same as mine then, 88spec and 90spec mixed interior.
Wouldn’t know mate ref interior - it’s the darker Recaro with red fleck? It’s all in storage for over a decade, I’ve forgotten all the details nowadays.
I had 2 RS’s - one had a rotten bulkhead and shell, was a write off so stripped it. That’s why this one is mixed red/white
I just fix mine inside valance, same fixing points mines is just loose,
I would sell it and yes it has an rst head,.
my interior seats and roof lining n pillar covers are 90spec, all speakers n sill plates rear door cards and back speakers are dark grey
Your is all 88 spec tho. I thought of changing mine to all 88 spec. I have a full spare 88 spec interior from headlining to carpet far my old xr3i
I will pm you and send a few pics, your away in Kent. About 500miles away
I’m saying dark grey, I think it is from memory but may be wrong, it was an original turbo that hadn’t been tampered with.
I had some RS7 couriered before Xmas, it’s possible to get it down if I get in to it.
Nice one Kev, I need to have a proper look as it looks the same!? The fans are slim line too.
it’s been -3 down here atm so haven’t been outside for a few weeks!
I'm pricing Omex atm now - might go straight for that whilst it’s being built.
[QUOTE=Andy_andyc;6824128]Spot on that mate, seriously.
cannot see how the bumper fits so well, I’ve brought a spare to cut up![/QUOTE
Im not sure if intercooler will get enough airflow there. So may be temp. I am going to get intercooler modified and fit in area where original went, but twice the size.
