- abs pump won't cut out
- Red top cam cover gaskets, leaks and torque setting?
- Tyre size
- Cossie headlight wipers..
- tensioner nut
- Dohc idle problem
- A couple of cossie paint codes ?
- Ebay RS500 intercooler ?
- Variable intake cam
- Ho knows grA sapphire jackbars how two fit ?
- 4x4 cossie modification advice
- 1993 sierra cosworth on eBay? fishy??? K387 ORH
- Rear lights Gaskets/Seals 3 door
- Removing a 4 door cossie (2wd) front bumper and rear spoiler?
- Xr4x4 front suspension upright
- Hello from me
- 4 door 2wd Cossie, what upgrades?
- Oil hose location help
- Saph 4x4 big brakes
- Sapphire cossie rear lights
- Ahmed bayjoo springs still available ?
- Steering wheel boss
- Cheap genuine amber indicator on Ebay
- AS Cosworth Breather 4x4
- Refurbishing Cloth Sapphire Recaro's
- Clutch Options
- Best place for silicon hoses?
- Would this offset fit 2wd Sapphire Cosworth
- 4x4 Saff wiring connectors
- 2.0 duratec in Sierra
- Sierra cosworth uprated diff mount question
- Weight of Various Sierra Parts for Importation
- Hella amber sapphire rear decorative strip
- Heat wrapping downpipe
- IW-025 Weber Injectors
- Cosworth Fan switch sapphire vs Escort
- 4x4 cossie oil pump
- Leather recaro. Who refbishes them
- 500 Intercooler to hart inlet manifold....
- Ford sierra cosworth 2wd
- Intermittent wiper
- HELP...sapphire heater vent
- head gasket question
- additional(new) +12V to ECU
- YB Timing Marks
- Chip install
- Cosworth Anti Camber shims
- 4x4 oils
- Recommendations for bodywork/paint places
- 4x4 crossmember & rack into 2wd
- Original 2wd Bonnet
- Front arb bushes
- Engine build please help
- bd14 inlet cam
- Interior Bulbs
- Immobiliser fault
- Rear beam bushes.. What is the preferred choice poly or solid?
- Adjustable TCAs
- idle sticking
- My first cossie
- What suspension?
- 3 Door Mk1 Seats re-upholster
- Earliest registered 4x4 saph cosworth
- 27 year refresh - can of worms
- 4x4 thermostat seal?
- Headlight issue
- Knackered 4x4 propshaft donut wanted
- jacking cover retaining strap photo
- boost pipes
- What coolant
- Brake conversion
- Gt30 on 4x4 exh manifold
- Amal valve alternative
- AP or Helix Organic
- Over fuelling cossie
- RS500 front bumper pics
- YB knock sensor frequency
- How to remove saph front seat belt?
- Where to buy new Pistons 9:1
- Wanted
- Like new just a few touches left
- 4x4 alloys
- Sapphire lowering suspension
- Fueling issues dohc
- Sierra sapphire cosworth spring length
- problem
- abs relay problems
- Wanted: Recommended turbo rebuilder in the Midlands
- Sierra sapphire suspension
- Cosworth cam followers
- Saph fog light surrounds - available any where?
- Ford motorsport steering shaft
- Gpa Sapphire cossie
- Cut out & won't start
- WANTED genuine boot lid
- cosworth 044 fuel pump
- Car has sat for 3 years - some hoses look like they need replacing
- 3 door track car project
- Issue with filling Saff with fuel...
- rebuilt engine running mega rich
- 4x4 Front inner CV Joints
- 2wd saph cosworth crank seals leaking
- Stereo wiring
- Rev counter/ temp gauge/battery light
- what engine oil to run in a fresh cosworth yb
- Group A exhaust
- 2WD Cosworth rack differences ?
- Propshaft oil leak
- Sierra 2.9 24v Options
- antifreeze
- 2wd spec oil pump
- testing
- Hydraulic Clutch Kit
- MSD Wasted spark instructions
- 2wd to 4x4 Doughnut and damper swap?
- For those with a bit of spare cash
- Rs sierra 4x4 inner rear arch replacement metal arches
- 17'' Calibre vintage wheels or similar
- Standard Fuel lines
- Saff 4x4 Cossie - charging problem
- yb cossie timing
- 3 door 2.9 conversion
- 3dr front tow eye
- 4x4 cosworth rear half shafts
- Pinto MT75
- Sierra sapphire 1.8lx
- Sapphire Cosworth K853JVW
- 2.0 Duratec tuning help
- How to separate hard plastic fuel line from steel fuel line?
- what year is my engine ?
- badly damaged crank pulley
- Cosworth fuel pumps Bosch vs. Sytec
- Running like a pig
- Alternative sierra sapphire 4x4 Power Steering Rack?
- 7bar of fuel pressure
- Water injection
- sierra 2wd over fuelling and hesitation problem
- fuel pump rewire
- Ford Sierra Saloon bootlid gas strut mod
- Side mouldings and boot stripe fitment
- distributor overhaul kit
- Sapphire Cosworth 4x4 parts wanted
- New Noisy tappets,am I using the correct oil???
- 3 door wheel colour
- Low boost help.
- 3dr running issues
- Sourcing oil separator adaptor/fittings
- Running with no oil cooler or Modine?
- Which Oil Pump
- Another crystal blue thread!! Just valeter well happy
- 6degree beam, roll bar choice
- What kind of Cams on big turbo engine?
- Bumper reinforcement brackets?
- Sierra 3 door
- cosworth no spark !!
- 4x4 head gasket
- Handbrake light flickering problem. Solved at last. Dodgy ecu earth!!!
- 2wd cosworth bellhousing
- Speedo drive retaining plate.
- fuel pump rewire
- Fuel smell
- anyone run omex 600 on their cossies ?
- Dohc Turbo Advice
- koni rear shocks
- Black smoke and oil loss
- Fuel vapour valve wanted
- Cosworth clutch quadrant
- cosworth green injectors
- Cosworth adjustable rear toe?
- Mikalor clamp sizes help please!
- was having start up issues, now car wont start up atall
- Sierra/Sapphire Doors
- 4x4 rear end on a 3 door?
- Cosworth 3 door
- powerflex Beam Bushes
- 2WD Front Wheel Bearing
- High idle on 2wd any ideas?
- Powder Coating
- Wing mirrors
- YB crankshaft oil seal cover
- 3 inch 3 door system - what's it worth - SOLD
- throttle position sensor
- which high pressure oil pump to fit?
- exhaust Carbon
- engine oil
- Sapphire recaros
- Smith and Jones
- Sytec Pumps
- 3dr cosworth side skirts material?
- Engine rebuild
- Center box recommendations
- trattling
- Burton Power Wheel Bearing
- YB camcover, £500????! eBay
- Saph 4x4 suspension assembly
- Found the Sapphire lol, First drive out for 2016
- Saph door mouldings
- A few spare wires
- where does this go
- Leaking Brake Bias Valve
- Alternative to dump valve on modified 2wd cosworth
- RELAY 83BG13A025CA 3 door cosworth
- 5.1cwp for 7.5in diff
- Powerflex strut top mounts
- J&R 4x4 driveshafts
- new reather or rebuild time
- saph 4x4 questions
- Sapph Sunroof Gear splines
- Genuine ford Sierra sill/ scuff plates
- Brake pump ABS Purple relay
- 1990 Ford Sierra Cosworth Injectors
- Cosworth Injectors
- Rear seat disassembly
- 4x4 Gearbox to Engine Bolts
- Car wont start from cold fuel pump wont switch off when ignition on
- 100mm airtec coolers
- 3 door front wheel position
- Sapph 4x4 running on 3 cylinders
- Loom plug connector pins
- PF09 TPS
- Rear brakes
- One very strange problem. Not starting when at temperature
- Cabin air filter from a Scorpio?
- Sapph Rear Trailing Arm ARB brackets
- 3dr rear quarter mouldings.
- cosworth engine loom
- cams
- Alloy Block 2.4 YB
- Pf09 / pf01
- recommended garages for Cosworth repairs North West?
- Help needed, Comp mo6 on a 4x4 Cossie
- P100 tailgate stays
- How to tell if shell is genuine
- 4x4 front diff removal
- Sapphire 2wd on lowering springs pic request
- Forge re-circulation valve
- L8 & p8 ecu
- Any saph cossies up for sale?
- 1990 4x4 Boot popping open over bumps
- 4x4 T3 turbo wanted
- number plate mount.
- Fitting drivers seat
- Sapphire Cosworth 4x4 TCA & Wheel Bearings
- Help with door locks
- PLEASE HELP! Zetec Conversion
- MSD fan loom connectors
- T34 boost hose
- sapphire driveshafts
- 2wd sierra cosworth steering rack part
- New Amber Front indicators on my 2wd Saff
