Dohc idle problem
Dohc idle problem
Hi,
I recenctly bought ik sierra 2.0i dohc With a broken head gasket.
I have rebuild the head, changed the timing chain en put the engine back together.
The problem is that it idle's at 1500rpm hot and cold. At constant speed it stutters, when i fully accelerate it runs fine and pulls good.
I have disconnected the idle speed control valve but it makes no difference. Alsof cleaned it out and tried aan different one.
Resident Wrestling Legend
They do have an idle screw, that's why you need to adjust it
Think it's an 8mm with a flat adjustment screw on the throttle housing you need to slacken off first
Then you need to slacken off the two tps screws a little so that it's naturally adjusted
This will drop the idle and then it's all good from there
Is it the one under the Tps it's a flat screw and kind off sonk in the housing. The other ones are for bolting the tb to the inlet
Ik have an picture, but dont knowhow how to upload it via smartphone.
