Adjustable TCAs
Adjustable TCAs
From what I've read there are 2 versions of adjustable TCAs around, one with the standard (bigger) ball joint and one with a smaller ball joint that doesn't last long. Where can you get the ones with the bigger ball joints?
And is the rose joint on the subframe mount not too harsh for a road car?
wesskitzo
I guess u mean adjustable tca's one has rose jointed end and is the bollox the other uses original ball joint which doesnt last long and then ur left with a useless part, the rosejointed ones when the roaejoint eventually dies can easily have the rose joint replaced. I have these they feel good and the steering is so much more precise and sharp
I had a look at the burton ones they looked good, hopefully Ade sees this thread as believe he has fitted some to his Sierra and without using a bladed anti roll bar so would be good to hear some feedback
difficult to really notice the difference as my car has adjustable top mounts,compression struts, bladed ARB, coilovers
Steve
Marc sierra (17-10-2016)
Must handle good Steve, what bladed arb do you run as most kits I've seen don't allow for fitment?
An MK Motorsport one, nice piece of kit
Combined with the MK 6 degree rear beam the mods found me over 2 seconds a lap at most tracks with the tyres lasting further into the race than ever before, usually my fastest laps were in the first 3 where as after fitment it could be lap 8 or 9
Steve
Steve
Steve
@ marc
I think these are the best option for you
http://www.compbrake.com/product/for...rms-pair-copy/
I've got them on my XR4i and they are pretty neat. They have the original rubbers on the inside at the sub frame.
I don't think they will do alot to adjust the camber on the car as it is only slightly longer than the original one.
i didn't see any diffrene in the balljoints coompared to the original ones.
I was indeed looking at those and the ones with the rose joints instead of the rubbers. But I wonder if the rose joints make the handling/feeling much better, or that they are only making the car harsh and rattle on the streets.
But I do expect you have enough adjustment range for the camber, as that is what they are intended for.
How much front camber are you running?
Compbrake sell the large and small ones, large use genuine TCA's as the donor where the small ones use copies as the donor, here is a pic I took years ago now to compare, right is a Compbrake large ball joint adjustable TCA, centre is a genuine 4x4 TCA, right was a Zoo adjustable TCA using a copy TCA as a donor:
The add from Compbrake actually says they are made from genuine arms:
"Adjustable in-situ, made with genuine arms and original bush". So I guess that should be good then. But I don't see any other TCAs with small ball joints on their website.
http://www.compbrake.com/product/for...olt-type-pair/
Fast Ford snapper
If there fine on yours then ade they'll be fine on mines lol
Ade (17-10-2016)
I wouldn't want to run without the arb. I first had the 28 mm front with the 18 mm rear and that gave me a bit too much understeer. So I changed the rear one to 21 mm, but that was too much oversteer. I now have a 20 mm rear arb and it still oversteered at some point. So ideally I was thinking of the 29 mm front arb from an Escort.
Removing the front arb completely seems a bad idea to me, as 1 mm change is already noticeable. Removing it will upset the balance and I don't want to run harder front springs to compensate.
I was also thinking whether it would be possible to fit a front mounted arb from for instance a bug eye Scorpio, together with a compression strut setup. But then the compression struts would need to have bushes between the TCAs, as with the standard arb, to make it suitable for the road.
Ade use his on track and for drifting, iirc also uses gaz gold coilovers
Fil
13
19-10-2016 07:44 PM
