View Full Version : Ford Escort RS Turbo
- rollarbearing turbo's
- Rs Decals
- Metering Head(changing)
- Sapphire Cosworth Leathers
- series 1 boost prob.
- Need a hole in the bulkhead >>>
- few bits concerning me
- Leaking Coolant?? What could it be??
- ignition timing?
- rear discs whats needed?
- Dump Valve not always going off ?
- Series 2-C Gearbox noise ?
- BLOW OR SUCK?
- samco's
- i want a front splitter
- whos car is ready for the summer then
- gearbox is weak even with uprated main bearing
- fitting a fixed bucket seat
- idle drop
- replacing the actuator..... how?????
- The s1 or the s2 help me decide
- Turbo advice urgently required
- 4 star petrol
- compression test
- Problem starting
- Anyone got a mint standard S1?
- this is wot u call a good answer!
- RS mud flaps
- Done me Brake Lines
- coolant level sensor????????
- Oil Light
- no hazards no horn
- RS Turbo motors are ......
- Lights gone off
- Hi everyone
- how do you make a rs handle?
- focus rs discs + calipers?
- running a rs on 3i inlet
- wonder what the lowest mileage S1 is in existance
- s1 miss fire
- Where was a series II built???????
- Turbo Spec and inlet manifold
- picture request
- Very strange electrical prob? S2.
- rs turbo smokes a lot when cold what does it sound like pls
- Where is she now??
- starting problems when warm
- Plugs on Inlet
- HOW LONG BEFORE I CAN PUT MY FOOT DOWN
- Difference between S1 + S2 exhausts?
- winter mods nearly complete
- What Oil to use after a rebuild?
- nearly stalls when I dip the clutch ?
- Gauges!!!!!!!!!!!!!!!
- bailey header tank
- Strut Braces
- good deal for Escort fans
- STANDARD ERST ALLOYS ****2 ONLY****
- ooohhhh nice ;)
- new springs
- removing...........
- Fuel pump relay's
- Where can i get....
- Clutch Cables
- NEW ALLOY WHEELS?
- Bonnet blocks!
- which alloys??
- SERIES1 RADIATOR ANY1
- SPARKPLUG QUESTION
- blown 'box!
- ROCKER COVER GASKET?
- NEW INJECTORS!
- Where to get Quad headlamps spares from?
- S2 INTERCOOLER INTO A S1
- Polished Rear Cage
- Hooray got my Ross Low Comp Forged Pistons Today!!
- silkolene pro r 15 50
- k and n panel filters do they work???
- best sparkplugs for s2 rst???
- Just joined the board!!! Newbie!!!!
- Dash options
- wot turbo
- wiring looms
- Cheap way of getting a Pace Intercooler
- Brakes
- Anyone heard of Ross low comp pistons before???
- HYBRID TURBOS
- Quarter Mile
- S1 Dash
- Series 1 Running Problem
- s2 fuel lines
- Where to get low comp pistons from for my S2
- fuse box
- Missing on idle
- Need Help
- Q on the Idle setting on the ERST
- s1 rst injectors were from
- 300mm brake conversion (nearly ready)
- S2 Headgasket Question??
- Removing Fuse box
- where do u get these back lights??
- couple of questions...............
- spark plug gaps
- fuel computer
- Plz delete that thrush post, it aint even funny!!!
- Chargcooler or intercooler?
- boosting problem in S2 turbo
- WET SPARK PLUGS?
- RST: Hot under the collar...
- get back to orange...
- CAR WAS RUNNING ON 3 CYINDERS
- Ecu
- no spark
- HT Lead HELP
- rs turbo cam kits
- rs turbo fuel pump relays?
- ERST Fuel Pressures?
- pro-alloy intercooler for s1?
- Ignition Problem
- Good Floor Mats
- S2 with power steering
- Undercar neons
- What is this?
- Turbo question
- help! ERST brakes
- Whats the difference in Turbos
- ATTENTION GRS USER'S
- zetec turbo
- S1PACE INTERCOOLER
- rs engine upgrades
- s2 turbo needs some love
- anyone help
- ecu's wiring diagram
- piccy request S1
- fuel computer probs
- IS MY TURBO CREAM CRACKED
- WHAT GRADE OIL DO YOU USE
- S2 drivers side drive shaft.
- hee haw
- coolant pipe routing!!!!!!
- cars died on me!
- s2 suspention setup, which is best???
- No Spark!!
- Free parts
- Ignition problem
- 4wd cossie disks and callipers?
- Fitting trigger sensor assembly to distributor on s2
- intermittant ignition cut
- good deal for Ford fans
- alarm help pls
- MEASURMENT FOR INDICATOR IN S1 WING
- mk v pedal box
- more help plz wiv the ZVH
- ZVH help??!!
- SERIES 1 WITH A SERIES 2 PACE INTERCOOLER?????
- Where can you get S1 side repeaters from?
- ecu feed probs!!!
- My RS Cabby
- Series 1 spot lights + brackets WANTED!!!!
- WHICH CLUTCH
- choice of turbo on a S2
- Intercooler Choice?
- SERIES 1 MK3 FORD WINGS WANTED
- help needed with my erst
- How much boost can I run
- Photo Request: Standard S1 - Exterior, Interior, Engine Bay
- S1 Problem
- 90 spec ERST clocks question...
- help wiv zvh
- standard Boost on ERST
- Gear box on a s2
- Ignition Timeing?
- I've still got a top end rattle
- S2 Steering Rack
- s2 runnin on 3.0l capri carb
- Escost cos rims on s2??
- which cage??
- No fuel to injectors
- Erst water/ heat problem- Help!
- Introducing me and my ride
- Piper exhaust
- modified car insurance
- Mk3/4 Bias pedal box....
- standed rst wheels and brakes
- Whats the best way to put an RS Bodykit on?
- Turbo Replacement
- All blue for sale
- Series 2 back fire
- irratic boost?
- Rear disc conversion causing offset problems
- S1 strutbrace on a S2
- Hello i need a picture of an RS logo to go on plates
- Overheating.........What Next!!
- swirl pot does it work?
- WOULD IT MAKE A DIFFERENCE?
- Well Lane Turbo Centre D/Valve
- Who done your rebuild?
- RS Turbo CVH, turbo oil return pipe
- Removing...Part 2
- Ford Overalls
- fuel injector pump
- series 1 turbo running problem??????? HELP!
- ZVH ENGINE
- Installed a new cam an still rattling
- How much are these worth?
- Escort S2 RS Turbo - Need Help!!
- pop, bang and flames!!!
- Escort S1 - Towing eye cover, Parcel Shelf, Dashboard Q's
- brackets 2 use 2wd cossie discs with standard calipers???
- Leaded or Unleaded
- neone got DTM Cup mirrors on their ERST?
- top speed
- rear brake shoes
- Finally got some nice Interior!
- RS Number Plates where can i get some from ?
- Lowering Help!!!!!!!!!!
- cossie calipers on a s1
- Brake Upgrade
- selecting gears?
- bailey dump valve any one ???
- Laguna splitter ?
- chrome strut brace from where?
- Will these wheels fit...?
- Wheels?
- RS Turbo Story (with a qeury)
- s1 colour change
- problem starting
- Idle problem when warming up
- Procedure for a new cam
- Bumpers, twin headlights, splitters etc......
- FANCY GOING ON THE FRONT COVER OF AUTO EXCHANGE
- new seats
- Cold starting problem !!!!!
- What Oil do you lad's use.....for your Box's?
- evil rust
- Gauges.
- Rocker Gasket!
- gearbox mount part number
- weird rev meter
- 90spec BUMPER?
- head gasket??????
- Zetec Pistons in ZVH
- S2 wont flame?? :(
- escort rs turbo smoking
- turbo timer
- S2 how much?
- anyone seen this around?
- Drivers side rear floor pan!
- speedo not workin?
- Rear disccs
