View Full Version : Ford Focus ST
- decat or not?
- ST170 help
- fan switch location?
- st170 subwoofer fitting/wiring
- St170 lambda and cat bracket problems. And wobbling under load please help
- focus ST oil leak! Please help
- VVT delete, advantages / disadvantages?
- Will Zetec gearbox fit ST170?
- ST170 inlet manifold swap/conversion?
- Side stripes, I want them.
- manifold heatsheld
- Coilovers for st170
- rear wiper
- St170 help needed
- stainless exshaust
- ST170 exhaust cam
- st170 mods
- Power loss after cambelt change. Please Read. ST170
- Mk1 St problem
- help on throtle bodies
- Coilovers - Jom coilovers
- Focus ST170 Running issues
- another project st170
- ignition interlockdevice
- St 170 Cam sensor
- St2 clutch issues
- Instrument Cluster
- Anybody got a ford st170 2004 user manual ?
- St engine swap.
- strut braces
- Winter = Clutch slip!
- ST170 juddering / loss of power
- Seatbelt pre tensioners
- Ford Focus st2 turbo removal
- Focus St170 Rear Caliper Thread
- battery light comes on
- Bonnet
- ST 170 Doors
- Do i have the PCV problem
- Ford focus st170 conrod size??
- St170 subframes
- ST170 small problems
- ST170 problems
- Cambelt change
- At170 low Rev bogging
- Loss of power after cambelt change
- Strut Braces
- st170 sports cat??
- .The the famous dsi clip
- St170 rough on start up
- ST170 Seat Rails
- Abs sensor wiring
- fuel rail for sale
- Please identify
- Which single mass fly wheel?
- imrc fix
- ST170 tuning in North East?
- focus st170 rear spoiler
- P0133 Reoccurring fault
- Speakers
- fans not working?
- Bought a ST170, cheap but niggles.
- ST170 Throttle Body
- ST170 offset and inset
- Grinding clutch st170
- st170, how many of each colour?
- car sluggish
- Level pedals
- Here she is finaly sussed it lol
- pic's
- [URL=http://s1293.photobucket.com/user/horsley1976/media/20140703_191139_zpsmk9sewy_e
- oz chrono 17inch
- 17inch chrono's
- my car let us know what you think, final up loaded lol.
- Finally think I've sussed the photo problem lol
- ST170 Production Info
- performance places
- Another post about pics sorry guy's
- posting pic's
- recomended lowering height
- new guy with st170
- st170 rattle at 2000 rpm
- Front body parts :-(
- ECU problem??
- Centre Caps - Will these fit
- Changing ST170 discs??
- Battery Relocation
- Rear Axle Handling Kit
- ecu swap
- Random Sensor found
- dreamscience or bluefin?
- imrc disconnet?
- vernier pully
- st170 exhaust
- St170 tapping noise
- dreamscience
- a good remapping place
- st170 disc and pads advice please
- st170 pads and dics advice
- cluster lights
- petrol
- handling mods
- Focus ST Start up
- St170 eml light on
- the value
- remapping
- performance mods
- clutch problems
- Focus st dyno / ABS issues
- focus st170 flat spots
- RS Body Kit - Sorry For Asking But....
- Focuses in motorsport
- Few niggly things I need advice on please
- Is the ST170 not 170 bhp from factory?
- Sunroof ST170
- ST170 Alternative inlet manifolds
- Focus rs MK2 injectors into MK2 ST fitting guide
- P1383 showing 9000 miles after cam belt change??
- Ford Focus ST
- ST170 engine light on
- P1518- st170 please help
- ST170 grinding noise issue
- service parts for st170 advice please
- ST170 - what's all the fuss
- Facelift
- headlight washers not working
- ST170 Help please!!!!
- Rattle in neutral
- Boost problem
- ST170 Lumpy & Loud Hissing from inlet area??
- Shake when power on ..focus st 225
- Diagnostic reader/scanner
- focus st
- ST170 - which flywheel?
- ST170 Wheel Refurb
- Help new
- Ford focus st 170
- Remapped ST170
- Ford focus st170 coil pack
- St170 vernier exhaust pulley
- rear caliper springs
- Focus ST 2 Oil filter housing diaphram fault
- Focus ST 3 Info - Any Good ?
- ST170 Hesitation/Juddering
- St170 cam locking tool
- Strange Noise (Help required)
- Focus st stage 3 boost pressure?
- general mintenace on 170
- Moddin' ST170
- ST170 misfire at 4500-5500rpm
- Focus St - Stock clutch with solid flywheel
- Low oil pressure...
- ST170 gear linkage help
- p0234 over boost??
- Procharger supercharger
- St170 drivers seat height adjustment
- headlight problem!!
- ST170 Cam Pulleys
- speed sensor location
- ST170 Cylinder Head info please!!
- Focus ST170 on Omex management
- St170 mods advice
- ST170 Gearbox Oil Capacity?
- Air Filter
- Focus st why so cheap now?
- Cfm billet under drive pully kit st 170
- ST170 rattle
- Battery relocation ST170
- Ford focus st170 scorpion cat back for sale
- Exhaust baffles
- Rs calipers on an st?
- Blue flame remap
- Ford focus st170 cat
- Help needed mk2 focus st
- New owner of st170 running rough
- st170 driveshaft query
- Focus St170, New Clutch And Slave Cylinder, Now Leaking Oil
- Remote Central Locking not working on ST170
- First post: 2014 ST
- back to standard 170
- ST170 fog lights
- MK2 st seats in a 170
- Centre cap adjustment
- N/S Headlight intermittent on st170
- coilovers
- New shape focus ST
- Ford focus st170
- St170 runnin problem
- sticking throttle pedal??
- Help: ST170 Parts needed
- Had the car on the rollers
- Dash flocking
- Water injecttion kits
- new breaks & knocking sound
- ST170 oil gauges to aftermarket sensors?
- ST170 alloy wheel fitment
- Panel filter
- St170 Xenon Headlights
- ST170 Reverse issues please help!!!
- ST170 Clutch Diameter?
- Track width
- st170 p/s pump
- ST170 & zetec people advice please
- Air vent gauge pods
- ST170 Splitter/Lip
- Error codes
- strange handling ussue, st170
- Automatic Air Deflector
- New To Site
- Few engine care questions on my ST170
- Ford Focus ST170 error code P1633 and Fuse 20 blowing
- St170 Bulb Change....
- ST170 with "Pipercams" Verniers -help needed.
- Focus st170 xenón help
- Bonnet won't release
- ST170 stainless exhaust and Air Filter
- ST170 question
- My ST170 project
- 6000cd head unit query ...white connector 4/5 wires?!
- Insurance companies
- Newbie saying hello
- ST170 Black Code live Remap
- St 170 owners tc fuse removal?
- Soon To Be A New Owner Of A ST170
- ST170 newbie - fog lights
- ST170 3dr One touch up/down on both windows
- 230mm clutch fit?
- ST170 spacers
- ST170 Problems
- ST170 newbie
- Might buy a Focus ST-3 what should i look out for?
- ST170 Head shake
- 1/4boost after oil filter housing change .
- Noisy turbo
- I need suspension, cai, wheel advice for my 06 St
- ST170 surging on right hand turns?
- S2 boss for a st170
- St170 gearbox
- cant get gearbox!!
- couple of st170 questions
- ST170 Starting problem/electrical issue?
- ST rear diffuser dimensions
- ST170 Overheating with AC on Problem Solved
- does the st170 focus
- Lacking power
- St170 review.
- St170 Clutch feels weird!
