View Full Version : Ford Focus ST
- Focus ST Boosting Normal??
- Focus ST170 04 Plate Electric window prob
- ST170 hard to select reverse
- boost soilenoid
- Any special tool required for front brake replacement?
- Annoying Rattle
- stuck for ideas
- Disappointed
- have i brought a nail ?
- RS Replica Wheels - Nut Problem
- New Owner for ST170
- Sorry for my ignorance but..
- Misfire?
- ST170 Inlet Camshaft Oil Seal Finis Code
- 2006 Focus ST boost question
- Limp mode after cam belt change
- focus problem
- zenon headlights st170
- 2002 ST170 problems starting
- advice on coilovers
- clutch wont bleed need help ASAP
- Focus ST170 Misfiring
- Focus st 170 p1118 fault code
- Mk Focus RS Front Brembos on a ST170
- Help and advice needed.......New Member First Post!!
- Replacing handbrake cable - ST170 Mk 1
- st170 hesitant at low revs
- Airtec Pro-Series Stage 1 - Cheapest place to buy?
- Ford Focus ST Clutch Change Help
- paddle clutch
- st170 usa parts buying
- st mk1 double din facia???????
- Will an ST170 engine/driveshaft take an RS Gearbox?
- powder coating alloy wheels??
- Bit help please
- A Few Questions
- ST170 clutch and flywheel change
- st 170 air filter question
- paddle clutch
- st170 tie rods
- stub axle/hub query
- st170 ride hight
- New ST170 owner, possible thermostat issue?
- Clutch? Fly wheel? Cam belt? :(
- ST170 tickover/idle adjustment
- Gauges not working
- Advice on ST170 Please
- The ST170 exhaust mani 3-bolt flange where to buy from?
- Good fast road brakes - Focus ST
- focus st170 reving high
- ST170 Rattly Cat
- ST170 front side lower arms
- focus st 170 exhaust
- Fuel consumption............sorry if I'm repeating.
- Can I fit ........
- time for an upgrade
- Hi from a new member
- ST170 lambda Ford or other brand?
- ST clutch and DMF
- 2002 st170 dual mass flywheel
- Indicators Not Flashing When Alram Set
- Smell of burning when running
- Need help mk1 focus seats
- Electric seat wiring for st170 interior
- Just bought an st170 estate
- ST170, power steering has died.
- st170 rumbling
- ST170 struggles to turnover, then misfire when cold start
- ST170 misfire and a redhot cat
- st170 gearbox
- Got an 04 ST170, Few Questions.
- st170 imrc again
- Advice
- ST170 Rear brake conversion
- powerworks supercharger
- Focus ST Boost Solenoid Valve
- New to the site
- New st170 estate owner
- new guy with a 170
- ST170 Engine Number ...
- Focus st turbo boost solenoid
- Anyone running MODX ?
- ST170 Cambelt Change - What parts are needed?
- st170 front subframe
- does anyone use a st170 as a daily
- Imrc box problem st170
- Getrag crownwheel diameter on ST170?
- Bluefin for st170 is it worth it?
- Water pump failure...I think
- 2nd, 4th and 6th Gears won't engage correctly
- Focus st turbo running gear
- gear slection problems
- Hole In Dashboard Can Anyone Tell Me What It Is?
- ecu location
- St170 P1381 - fault code after timing belt change
- Focus st engine management light
- ST 170 to Zetec Flywheel?
- 2002 st70 heater problem
- 2002 ford focus st170
- ST170 part help
- ST170 sump same as black top sump?
- ST170 Front Chin
- Show us your ST
- st170 clutch problem - can anyone help?
- Focus st engine replacement
- helppp!!!! ST170 help!!!!!!!
- st170 dual mass removal
- st170 fuel pump
- iphone to Radio connection on ST-2 08 plate
- Hello guys and girls
- advice on removing st 170 engine please
- thinking of getting a st
- ST 170 6-speed Master Cylinder
- Focus ST MPG????
- St170 Clutch Problem
- Decent garage in middlesex
- ST170 Sunroof Drains
- Sensor Location
- MPG and the effects of Bluefin on Focus ST170
- ST 170 leaking by pedal
- Clutch master cylinder bleeding
- Just bought ST170 and have a couple of issues.
- 'Clunk' Noise
- New ST 170 Owner, a couple of questions
- ST170 engine upgrades bhp!
- New Member with a problem
- DTC fault code D262?
- Handbrake not working on one wheel - what did I miss?
- lightend fly problem st170
- Need help with new bits due to leak.
- St170 - Standard manufacturers warranty
- st170 - p1381 fault code
- st170 exhaust vernier questions?
- Recommend a code scanner for ST170
- 2007 Focus ST Clutch Vibrating
- focus ST/RS Boost control valve
- ShedT170
- ST170 Clutch and flywheel
- ST170 Set up
- Ford Focus ST170 on natural gas (LPG)
- IMRC issues
- Wiring Focus st170 clocks & speedo
- N/A Error Code
- st170 wont start HELP PLEASE
- Windows keep misting up
- Quick "hello"
- Stloen dads ford capri 2.8i
- Focus Time Attack 2013 look
- Side repeater not working
- How do I remove the imrc cable from car
- Timing Belt Came Off, Please Help...
- IMRC not working
- interior lights
- Needing some help please on parts etc
- ST170 Cambelt replace - Update
- Newbie!
- Gaz shocks for sale
- Auto Windows
- Seat belt warning
- Headlamp Adjuster wanted
- ST170 ABS Light issue
- ST170 Head Gasket
- rev limiter
- any ideas what this is?
- St170 clutch
- ST170 exhaust system
- thinking of buying an ST170
- ST170 Single DIN conversion...
- Newbie st170
- ST170 in a bad way :(
- Focus ST....RS parts, what will fit?
- New Focus ST
- Fuel pump info req
- Anyone got an ST170 speedo sensor plug?
- Dash bulb in mk1 st
- st170 conversion
- Boost controllers
- opinions???
- st170 high idle when cold
- ST cambelt
- Ford focus st
- ST170 thermostat housing
- cool focus ST video
- ST170....Now got a fuel issue (hopefully the last one!)
- ST170 Drivers Seat !!
- st170 inlet manifold control
- ST170 ABS Dash Light has come on
- How to make focus st pop alot?
- Throttle pedal vibration
- Forced air induction kit
- vvt solenoid st170
- focus st xenons
- help! engine maintenance light
- Exhaust Diameter V's BHP
- Spring for st170 IMRC
- ESP 2.0 and st170 difference?
- ST170 Coil Wires
- Tuning Focus STs
- Focus ST170 decat pipe and ewl
- p1518 but head scratcher
- Newbie Alert
- Recommended garage in CR3 area
- ST170 Bluefin
- ST170 won't start
- ST170 EML on since air filter change.
- exhaust diameter
- Focus ST pistons
- 2k rpm power loss st170
- can any1 clear up coilovers
- part
- st170 estate abs and traction control fault
- ST170 rocker cover bolt size ?
- ST170 Estate for sale in Blackburn STAY AWAY
- ST170 "pinking"
- steering rack
- ST170 Sump Replacement
- ST170 Estates
- focus st advice
- St170 Timing belt snapped and blew the inlet manifold off!
- brake fluid
- Facelift focus
- Oil-way plug thread
- Anyone got pumaspeed throttle body on their ST170?
- ST170 Rocker Cover Change
- St170 tapping noise
- Focus ST170 Turbo projects, the beginnings
- steering rack st170
- ST170 Suspension saga
- stereo help and advice
- st170 stereo help and andice
- Focus St225 engined race car
- twin tailpipe conversion for st170
- Wanting to sell my ST170?Advice please....
- Clocks fail and won't start
- St 170 sub and wiring please help info needed
- ST170 Wiring Diagrams
- wanted
- ST170 Sump, why so expensive???
- St170 loom and ecu
- a few pics of my new interior
- ST170 Scrap Bits
- ST170, rubbing noise with Eibachs
- st engine and gearbox
- ST 225 starting problems
- starting problems
- St170 wheel caps
- easiest way to turbo my st170 ??
- ST170 xenon problems....
- idle problems
- tc and abs question st170
