clutch wont bleed need help ASAP
Old Jun 7, 2013 | 09:13 PM
89luke89's Avatar
89luke89
Default clutch wont bleed need help ASAP
hi guys ive just replaced the clutch on my st170 along with the slave cylinder but now it wont bleed what so ever! ive tried the manual way like you would a brake but nothing. i went a got a pressure bleeder hooked it up open the nipple and still nothing come out. i even tried manual bleeding with the pressure bleeder hooked up but still no fluid coming through. im getting so frustrated now thanks luke
Old Jun 7, 2013 | 09:20 PM
the_frozen_one's Avatar
the_frozen_one
Is the pot full to the brim? The fluid intake for the clutch is usually right at the top, if it's only at 'max' the clutch pot probably can't draw anything in
Old Jun 7, 2013 | 09:22 PM
89luke89's Avatar
89luke89
i made sure it was right to the top, i dont see why im having so much agg lol
Old Jun 7, 2013 | 09:27 PM
Mark_'s Avatar
Mark_
Is the pedal up or down?
Had trouble bleeding my Cupra R clutch, I pulled the pedal up by hand and then pressure bleed it.
Old Jun 7, 2013 | 09:29 PM
botters's Avatar
botters
competant bodger
put a pipe on bleed nipple and suck till fluid comes through, dont get any in your mouth tho it dont taste too great
89luke89's Avatar
89luke89
the pedal is sitting where it should it just has no pressure and theres no fluid coming through the bleed nipple, ive been out there half the day doing this lol
Old Jun 7, 2013 | 09:35 PM
botters's Avatar
botters
competant bodger
you are doing the press clutch and hold, open bleed nipple, close bleed nipple, release clutch method arnt you and not just pumping the pedal with the nipple open?
Old Jun 7, 2013 | 09:38 PM
89luke89's Avatar
89luke89
yea hold pedal down open the close then release the pedal
Old Jun 7, 2013 | 09:43 PM
botters's Avatar
botters
competant bodger
try sucking it through first then, you sure the new slave hasnt "popped" and is filling the bellhousing with fluid, the amount of times ive had this happen is a joke and is now why, when doing any clutch with hydraulic operation i fit the box with two bolts then bleed the clutch before building the car back up
Old Jun 7, 2013 | 09:45 PM
89luke89's Avatar
89luke89
the fluid isnt even going down in the res tho no matter how much i pump it doesnt use any if i open up the bleed nipple and pump the pedal i can hear air pushing and pulling
Old Jun 7, 2013 | 09:47 PM
botters's Avatar
botters
competant bodger
like i said then suck it through it will sort it mate, once you have sucked it through bleed it as normal
Old Jun 7, 2013 | 09:49 PM
89luke89's Avatar
89luke89
cheers mate i will give it ago fingers crossed!
Old Jun 7, 2013 | 10:56 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Get yourself a gunson eezibleed kit. They are about Ł20 in halfords. Just need the air from the spare so no need for some one to pump the pedal.
Old Jun 8, 2013 | 07:40 AM
matsgarage's Avatar
matsgarage
Go to your local vets (yes, really) and ask for a 50/60 mil syringe, they will probably give you one free.
Fix some rubber/plastic tube on it.
Suck up some clean brake fluid, without any air bubbles in.
Attach to slave cylinder bleed nipple and then open it.
Pump the fluid out of the syringe, effectively bleeding it backwards (the fluid may overflow from the reservoir if it's full)
You may need to do repeat once or twice to get all the air out.
Works everytime and you don't even need to touch the pedal.
Hope this helps
Old Jun 8, 2013 | 08:43 AM
89luke89's Avatar
89luke89
Ive been trying with that eezie bleed kit got it from gsf. Could my master cylinder be fooked? As ive tried pushing the fluid back up the system and still get nothing coming back to the res just alot of pressure in the syringe
Old Jun 8, 2013 | 06:14 PM
89luke89's Avatar
89luke89
thanks for all the fast replies it turned out to be the master was blocked somehow, went and got a new one fitted it and boom bleed up straight away
Old Jun 8, 2013 | 06:34 PM
davidg5506's Avatar
davidg5506
Cool glad u got sorted
Old Jun 8, 2013 | 06:39 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
Nice one .
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
