ST170 "pinking"
I have never come accross this before on a duratec or zetec for that matter, my mate just bought a really nice st170 and noticed it on the drive home, its drives and pulls well through the gears but when changing up under load he gets pinking until it reaches 2500 revs, I could only suggest using higher octaine fuel, plugs, leads and coil pack, he has in the last week changed the lot and his one still does it, any ideas on where I can tell him to go next as I was thinking the AFM
the only fault he has is pinking which fades out as he goes through the revs, never seen this before on one of these engines, in the old days it was a timing issue but on these engines its pre set with no alteration
I cant help with this problem of your mates, but my st has exactly the same problem. As you im at a loss as to what is causing it, the only thing i was going to try was to clean or replace the MAF sensor??
My st even pinks on the overrun!! Its an 03 and runs superbly otherwise..
Apologies, re-read your post again and noticed the MAF is on your list to do also.
Chris.
Andypandy260
Sep 23, 2015 10:28 PM
