ST170 Head Gasket
Old Oct 4, 2012 | 08:21 PM
toro89's Avatar
toro89
Question ST170 Head Gasket
Hi
i think the head gaskets gone, well a mechanic is saying that, just want your opinion on what might you think it is.
basically the thermostat housing is leaking, was supposed to be fixed today. the car failed to start and it only did after turning the ignition a load of times. the leak is so bad that a full tank of coolant/water was gone in a day. now i can clearly see the leak but he was saying that the cylinder is flooded and is misfiring. would that be from the head gasket or the faulty thermostat housing?
hoping its not the HG seeing that it will cost way more money to fix. also there is white smoke coming from the exhaust.
if anyone has any ideas, i'd appreciate it.
Thanks
Old Oct 10, 2012 | 01:18 PM
Sp3no's Avatar
Sp3no
Sounds like you or someone else has run it too low on coolant due to the leak and it probably has cooked your head gasket. Fixing the thermostate would have been allot cheaper than doing the headgasket
Lesson learned i hope, this is gonna a fair whack of money
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Marv888
Sep 26, 2015 03:44 PM
