View Full Version : Ford Focus ST
- problems after using obd2 bluetooth code reader
- Help on buying an ST
- st170 engine knocking
- Dashboard lights
- hi were can i get a cheapish decat pipe from for mt st170
- ST170 MPG
- St170 brakes option
- ST170 won't start again. Help please!
- does the st170 have a mpg gauge on the dash
- Will MK1 RS Seats Fit ST170
- ST 225 Owners, input required please.
- St170 Help!
- 170 rear window wiper
- ST170 parts
- Squeeling ST170
- what gains would i get from a bluefin st170
- ST170 Starting problems
- St170
- St170 exhuast system
- Variable Valve Timing Solenoid
- Pipe Collapsing on ST170
- ST170 Sports cat options....
- Buying st170
- will 5 speed box mate up to st170?
- Throttle Cable ( roll eyes)
- ST170 Gearbox Oil
- focus rs conversion on st 170
- inlet manifold flaps stuck open st170
- Help st3 to rs500
- ST170 Thermostat
- AirTech Gen 3 Intercooler
- Good Garages in Birmingham Area
- Air Filter Pipe
- ST170 How to find alarm sensor in bonnet please
- St170 camshaft seals
- Power loss at high revs
- 20% emisions help
- gauge question
- ST170 Clutch pedal clicks when being depressed
- Wheel centre caps...
- ST170 Standard Exhaust
- coolant dribble near front bumper???st170. odd one
- Turbo correct working
- st170 exhaust cam pulley
- thermostat housing leak st170...looks like plug weaping?
- Temperature problem
- is there a torque limiter on the st170
- ST170 cambelt change
- a few probs with st3
- st170 rear brakes
- Upcoming Sump pan change(st170)
- Focus ST Turbo issue
- Car juddering at low speeds (Usually around 20mph)
- st170 codes 1131, 1132
- ford focus st (standard)
- Stumbling and high fuel consumption
- st170 imrc p1518 sticking manifold flaps
- inlet runner control
- st170 xenon question
- IMRC probs!
- Mk2 Bumper to a Titanium
- st170 sounds like a diesel on idle???
- Looking for a price
- how many miles to a tank do st owners get?
- st170 dipstick...oil capacity/level wierd one.help!!
- ST170 stalk adaptor
- ST170 value/prices lately ?? help please
- waterpump goosed on st170
- HELP gauges playing up!
- BN07 HVG Anyone know this car??
- heat shield removal
- ST vs normal focus
- st170 engine trouble
- 2004 st170 abs pump issue
- DTC P0234 engine overboost condition?
- banging on the arches
- ST170 springs
- confusing engine driving
- Worth getting a exhaust?
- st170 whine
- front heated windscreen
- st170 throttle bodies info
- Oil in Air filter box
- ST170 power issue.
- Facelift st bumper
- high miles st170s
- ST170 - Rusty & Leaking Sump
- steering prblems
- ST170 CFM Throttle Body
- Old key fob/central locking issue new twist
- SD03 MWC
- Focus St170 Modifications/Power Increases?
- Threads asking for Car Stereo codes are not allowed.
- Blacktop lifters in a st170 head
- fuel pump
- ST170 Help
- Got an Asbo... - Now replaced
- focus st
- quick vid of my st
- induction upgrade
- ST170 the lighting on the dials
- advice with lowering a st170
- ST170 common oil leaks?
- bluefin???
- ST170 strange noise
- Engine light reset
- st170 c.d player
- newbie
- st170 seats question
- ST170 exhaust vernier pulley
- new st170 owner needs pointing in right direction...
- ST170 throwing up fault code P0190
- help wanted with imrc
- New Member needs your help
- st 170 code error
- Help required !
- Thinking of buying an st
- St170 speaker watt question
- Focus ST170 Cam Timing
- Oil temp gauge
- tyre help
- Harness Bar
- st170 clutch 2002
- BL53 DXE stolen from coleshill birmingham
- Focus st 170 breaking imacculate
- Normal Focus brake caliper for ST170?
- Fault Codes
- st220 gearknob on st170
- removing st170 front discs
- temp guage
- st170 fault code p1518
- St170 Steering issue
- Pinking....??
- ST170 dark headlamps
- ST170 oil cooler take-off
- st170 natural aspiration tuning
- audiophile package
- ST170 Traction Control Issue Maybe
- focus st 170 centre caps?
- ST - Missing and no boost from cold p- but fine when warm?
- focus st failed mot on play in steering rack?
- st170 fault code
- ST170 audio
- st170 cat back exhaust (i hate it)
- MK2 different wheel options...
- st 170 coilover advice
- Central locking problem
- Under-bonnet insulation
- Focus st 170 clutch change
- AIr con not working
- ST170 Timing belt change - couple of issues
- Lambda Sensor Not Heating
- 2004 st170 vin number
- Good Vibrations!!!!!
- Is it worth 'tinkering' with my ST170?
- st170 replacement engine
- Newbie needing advice please
- Hello new to the Site
- ST170 on ITB's, which cams?
- eml lights and inlet manifold runner cables
- smoke on acceleration
- ST170 oil pressure
- ST170 Throttle body manifold
- MPG
- st170 clocks
- code P1383, ST170
- Power steering prob help
- St170 full closure not working
- can`t post any pics.....??
- my timing belt or my teeth ??
- st170 reverse light problem
- dream sceince
- new st owner
- Focus st170
- My st170 pictures
- ST doors
- St170 Advice
- Need advice on thermostat housing leak
- AirCon only works on 3 and 4 settings
- St170/ cutting out problem
- timing belt aux belt?
- Mk2 Focus ST Version 1,2,3
- st170 headlight querie
- ST170 Turbo Build
- best mods for the st170
- new user, sawp ST170/ST225
- focus st?
- Are st170 seats able to adjust lower than STD seats?
- Cosworth fitment et35 18's on st170
- ST170 Runs Rough when hot
- Focus rs wheels on st170??
- st170 lambda sensor
- St170 Tuning advice?
- ST170 Service & Timing Belt Prices
- ST170 and 1.8 ancillaries
- St170 speaker question advice??
- st170 mpg
- fault codes on focus st 225
- St170 pics on different wheels please
- Wheels to fit an ST170
- ST 225, remap, Fuel economy question?
- St170 advice
- focus st170
- focas st
- Oil for ST170.
- st170 running problem
- Exhaust Vernier Pulley for ST170
- focus st blackeyes
- st170 noisey engine !!!!
- magnum grey st170 pics please
- which springs for st170 ???
- focus st170 paint warranty query
- St170 uneaven suspension !
- St170 acclerator problem
- Focus ST225 Exhaust info
- St170 turbo manifold, quick yes /no answer please :)
- Ford focus ST dash clocks problem
- Focus 2.0 Zetec Focus st170
- Ford focus st170 Brakes
- New Focus ST-3 Owner
- ST exhaust system on standard Zetec
- i've 70% bought an st170!
- St170 jobs to do
- st170 gear cables
- st170 fuel
- ST170 clutch
- Focus ST170 Headlights
- ST170 What Next
- st170 NEED HELP
- st170 subwoofer
- Focus ST 225 loss of boost pressure
- hepl wanted wiv wring up st 170 engine
- lowering st170
- Oil Filter Housing Replacement
- need help with focus st no boost!!! OIL FILTER HOUSING REPLACEMENT
- Focus ST3 exhaust Upgrade
- st170 transplant
- New owner of Focus ST - help
- st rear bumper support brackets
- Ford focus ST170 Brakes and Tyres
- St170 gsxr itb wanted
- st170 judders/loss of power when hot??? help!!
- couple of st1170 probs
- turbocharging a st170?
- Accelerator sticking on my st170
- st170 induction kits?
- st front bumper
- st170 upgrade parts
- St170 headlight question
