ST170 - Rusty & Leaking Sump
Old Nov 25, 2011 | 03:05 PM
MattEMUlsion's Avatar
MattEMUlsion
Default ST170 - Rusty & Leaking Sump
Well the oil sump on my ST170 is in a pretty poor state, leaking, corroded all over and in desperate need of replacement. Has anyone got any advise or words of wisdom before I tackle the job? I am thinking of getting a non-genuine replacement sump and obviously some kind of sealer to do the job.
Old Jun 6, 2012 | 10:46 AM
ianjk's Avatar
ianjk
Hello,
Found this when searching for the same problem with my ST170, not sure if this will help but I have two options for my issue.
Wire brush the oil sump and spray with Lithium grease (my sump isn't leaking that badly) and see how it gets on.
If that doesn't stop the problem, then I'll buy a replacement from eBay and replace myself - at least a two hour job as garage I trust and use regularly told it it would cost around £350 for parts and labour.
Old Jun 8, 2012 | 02:15 PM
khanny1's Avatar
khanny1
sounds very expensive just for a sump change, its only a case of oil out, cat off, sump of then reversal, 1 hour job 2 hours tops
Old Jun 8, 2012 | 02:20 PM
ianjk's Avatar
ianjk
Its because most garages will quote the original ford sump part, which costs £250, not the OEM ones you can get for around £50. As you say, two hour job, bit messy, but ultimatley saves a bundle of hard earned cash.
timsrs
Nov 13, 2018 11:48 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
youngben
Sep 27, 2015 09:37 PM
