st170 codes 1131, 1132
Old Jan 29, 2012 | 06:02 PM
seddo's Avatar
seddo
Default st170 codes 1131, 1132
hi ppl i used a diagnostic tester yesterday with the engine managment light which came on an came ack with these faults to do with fueling becoming lean in engine. has anybody had these fault codes an if they did what did you do to fix it. thanks for replies.
jay
Old Jan 29, 2012 | 06:06 PM
RichieST's Avatar
RichieST
Pre-cat lambda sensor faulty most likely. Quite common for these to fail on the st170.
Old Feb 7, 2012 | 05:10 PM
seddo's Avatar
seddo
Hi mate thanks for the reply but if it was to be faulty would the car show up the code 0135 I think that the code. I've checked around an can't find vacuum leaks, checked maf. I can feel the car lose power once it warm. Confused. The car had both lambas replaced in 2010
Old Feb 10, 2012 | 09:09 PM
seddo's Avatar
seddo
Also the car tends to just lose power at times when warm and got roughly 28 miles to £10 worth of fuel @ 1.33pl. Hoping it is the sensor. Anybody know best place to get precat sensor?
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Sp3no
Sep 27, 2015 07:23 PM
Marv888
Sep 26, 2015 03:44 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
