ST170 on ITB's, which cams?
Old Jun 16, 2011 | 08:19 PM
siany1997's Avatar
siany1997
Default ST170 on ITB's, which cams?
I have gsxr 750 throttle bodies, and an Omex loom for the 170 . Omex ecu to buy when I grit my teeth hard enough and sink a few beers to take the pain away
Can anyone recommend decent cams for the job ?
Old Jun 16, 2011 | 08:32 PM
mikey p's Avatar
mikey p
standard cams are good for 200bhp on tbs.
other than that piper do a exhaust cam and cat cams do both with various profiles.
but the cat cams are big money.
Old Jun 17, 2011 | 11:50 AM
AustenW's Avatar
AustenW
Get some 13mm plus cams and piston cut outs done and you will see some good numbers
If you go with Cat Cams they do a cam to remove the VVT
A friend of mine has seen 270bhp on an ST170 engine but it had high comp, headwork and a huge cams on TB's nasp
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Mc5506
Oct 5, 2015 09:57 PM
