Accelerator sticking on my st170
Newbie here,ive recently purchased an 52 plate st170,i am really pleased with it apart from an annoying accelerator pedal which is sticking quite badly atm,any advice on solving this would be great,other than that its fantastic
You sure it's the accelerator sticking? Try and get it to do it with the bonnet open, and engine running. See if you can close the throttle by hand..
I say this because it's more likely be the idle control valve sticking open if the car just sits there and revs at 3000rpm or so.
If not, new throttle cable.
I get this aswell. It seems to have come in with the cold weather.
Check for a vibration through the pedal aswell, I also get this so i'd assume a new throttle cable is needed if you start getting that too...
Anybody know if you would release abit more power with a new throttle cable, as ive heard it can cause the butterfly to not open fully?
Thanks for the advice guys
Honda's seem to suffer with this. My mate's accord did it and my dad's civic does it. Really hard to press the throttle pedal, makes it really hard to drive smoothly!
Is supposed to be the cable that causes it. Move the throttle body by hand first to see if it moves freely, that would disregard that.
Vibration through the throttle pedal can be caused due to the cable being to short, the fix was a stupid long cable, as said above clean the throttle body out. The throttle cable can cause a loss in performance when it is adjusted incorrectly and at WOT the butterfly is not fully open, this is fixed by correctly adjusting the cable.
Thanks for all your help with this
i cleaned mine out today, i had the same problem, its feels so much better, but i also suffer from the dreaded accelerator cable vibration, does anyone know how easy or hard these are to replace yourself?
SMILER258
Sep 28, 2015 09:04 AM
